Spark plug removal problem
Old 11-30-10, 11:51 PM
Skip2MyPou's Avatar
I've never really encountered this problem before... but is there some sort of special tool I could use to get my plugs out???
Old 12-01-10, 12:02 AM
those look like BRxEIX plugs..... you'll need a 'special' socket that has had the outer circumference ground down to fit. Not sure where you can buy them currently, KG parts used to but I don't think he does any more.
One more reason to use the proper spark plugs IMO, I'm guessing the previous owner left you a nice surprise
Old 12-01-10, 12:03 AM
prew's Avatar
You need one of these:
http://www.racingbeat.com/RX8/Ignition/11529.html
Some people make their own, I currently need one too.
Old 12-01-10, 08:02 AM
Rotary Specialists
RX7Club Vendor
Banzai-Racing's Avatar
Wow $77 for a spark plug socket?
Go pick up a cheap 13/16 for $4 and start grinding, then when you get those plugs out, buy the proper ones that are the correct size/length
Stock & Race plugs http://banzai-racing.com/store/93+_r...ark_plugs.html
Old 12-01-10, 08:33 AM
Eh
djseven's Avatar
You can get a cheap grinder from Harbor Freight for $30.00 and still have a useful tool left when done.
Old 12-01-10, 09:24 AM
rotorhead
arghx's Avatar
speaking from experience, grinding down a socket is a big pain in the ***. The socket has to be very thin and it has to be ground down evenly to work. If you grind it too thin in one area the socket can split as you are trying to turn the plug, and then worst case scenario you can ruin the hex on the socket. just buy the socket and you'll never have to worry
Old 12-01-10, 10:11 AM
Rotary Specialists
RX7Club Vendor
It takes all of 20 minutes (max) to modify. Pretty simple, just keep spinning while grinding.... It is not like it has to be precision machined to remove 4 plugs.
OR you can order a $77+shipping uni-use tool and wait a week for it.
Old 12-01-10, 09:44 PM
zammm's Avatar
I just grinded mine down with an attachment i put on my drill....wasnt too bad...
Old 12-01-10, 11:34 PM
Autocrossed. I got CONED!
EricRyan's Avatar
Agreed 100%. For that price you could try it 10 times and still not pass the 80 dollar mark.
Old 12-01-10, 11:51 PM
Sharp Claws
RotaryEvolution's Avatar
cheapo racing 10.5's have inset heads on them such as that. considering the platinum 10.5s are a rediculous $40 each, the socket is a cheap investment.
granted those aren't NGKs so i have no idea what he has.
Old 12-02-10, 03:26 AM
jpar196's Avatar
I have done this to mine, grab an angle grinder and start grinding until basically the socket edge becomes sharp. then sand it down to smooth it a bit, give it a good wash and go.
Yet its still not easy with the ground down socket. this is why Im chaning to the proper plugs next time.
Old 12-03-10, 02:03 AM
SideWayZ The Only Way
FD3S2005's Avatar
i have done this 3 times, first time worked and had not problems grinding it, but i ended up dropping it from my shelf and it cracked the thin part, second time i ended up grinding it to much, third one i have had and have changed the plugs 4 times with it and doesnt look like its cracking or anything.
Old 07-05-11, 11:15 PM
RedX7FD's Avatar
CA Does anyone?....
Do any of you guys have pix of a custom made socket b/c I'm having the same issue? Any pix would be appreciated =) Thanks guys Oh yes $77 for a darn socket lol RacingBeat is making a killing of this, I've given it some thought, but rather try to grind a regular socket first.
Old 07-05-11, 11:25 PM
Skip2MyPou's Avatar
I ended up grinding a socket piece down. Nothing really much to it haha. I can post a pic when I can if you really want one.
Old 07-06-11, 10:22 AM
RedX7FD's Avatar
thanks
Thanks lol just want to do it right the first time around lol
Old 07-06-11, 04:16 PM
Skip2MyPou's Avatar
No problem at all haha. I just took some pictures with my phone. Hope this helps.
Old 07-06-11, 05:52 PM
RedX7FD's Avatar
Sweet!! Thank You Skip2 =) Now I can get to work lol
Old 07-06-11, 06:30 PM
Skip2MyPou's Avatar
Hahah anytime. Hope everything goes to planned with no nasty surprises.
07-01-23 04:40 PM
The1Sun
03-18-18 11:08 PM
Skeese
65
03-28-17 03:30 PM
alphawolff
11-17-15 05:57 PM
Joe428
16
08-19-15 06:24 PM
Quick Reply: Spark plug removal problem
