Bridge Port?
Bridge Port?
Hi,
I am a total newby to rotary engines. I have lots of experience with piston engines and also 2stroke shifter kart engines, but not rotaries.
Looking to get info and questions answered like what is a Bridge Port mod? Also, what are the differences between a regular 13B and a BREW??
I am looking to build an FD that will see a lot of track time. It won't be a full on wheel to wheel race car, but it will be durable enough to withstand all day abuse at a track. What is a safe amount of boost without blowing the seals and doing other damage, what else are weak spots on these cars?
I read some posts here about single turbos and seems that there is no definite answer as to which setup is better (for track use, that is). I am looking to make about 400 to 450 at the engine. Will stock turbos with a boost controller handle it?
Also I read that in Japan, they had a better ABS system than us cars. Is this true?
Where can I find information to those questions? Any help is highly appreciated.
I have searched here, wiki and google.
http://www.mazdarotary.net/porting.htm
If you intend to track the car, the turbo won't be your primary concern. It will be the cooling system needing the most work. The FD cooling system is, how shall we say, inadequate and poorly designed.
400HP at the engine is fairly easy and one of the best turbos for a stock or street port 13B is the GT35R. There are plenty of kits available and the thing makes boost like the stock turbo.
Bridgeport is a porting modification that opens the intake a whole bunch. It's not really streetable.
13B is the engine found in 2nd gen and later 1st gen RX-7s. The 13B-REW is a later version with twin turbos added on. The 13B-REW is the stock engine in the 3rd gen RX-7.
Yes you can make a trackable FD. Oil cooling and water cooling system mods are a must. Low-heat turbo setups like a single turbo help a lot. Auxiliary injection systems help immensely.
The ABS system on US-built FDs is a 8-bit system. It went to 16-bit in 99 I think. I know a few folks who have updated but it's not considered a critical mod. Many track guys prefer a big brake kit and no ABS. In any case the stock ABS systems are not that bad for tracking and they will help save your tires.
You will find a lot of info in the 3rd Gen FAQ. Howard Coleman has built a great car with your exact needs in mind.
Thanks for the info. I will look into me Coleman to see what else I can find.
Out of curiosity, is a single turbo the preferred setup? Any drawbacks? What's the boost level that you want to be at for road racing type application?
Aside from cooling mods like oil coolers and radiators, what seems to be a weak point in an fd? Seals?
I will keep searching and thanks for the info
Basically, replace all the plastic parts in the engine bay, get as much airflow as you can through the rad/intercooler/oil cooler and run a well tuned standalone. The enemy of the FD is heat and from the factory, they were a thermal disaster. Removing the stock twins and precat goes a long way to eliminating this heat but remember the radiator is almost horizontal. It's ducted, but in practice this doesn't work well.
Trending Topics
looking forward to it.....
When I drove my friends FD, I was totally blown away. It was like: how did this car go under my radar for so many years??
It was probably from driving Formula Mazda and being so apalled by the puke like sound.....
The FD, on the other hand, slightly muffled and with a bridge port mod, the idle was one of the best I've ever heard.
One thing to mention is that if you are bridgeporting the engine, a GT35R is far too small. I'm not sure from your posts if you have decided to go that route or stick with a stock/street port.
I was going to build a 240sx, but after driving my friend's, I am pretty sure I will get an FD and mod it to suit my needs for a track car.
If a 35R is too small, I will have to get something bigger like a 40 or something.
I was just amazed at the handling aspect. Very similar to my S2000 race car that I had, but without the limitations of the F20 engine and the weak drivetrain.
D
danielbradley2
11
Sep 28, 2015 10:44 PM
scissorhands
Sep 16, 2015 01:25 PM
