MY CARS RUNNING LIKE Stuff>>> NEED HELP..
Old Sep 22, 2004 | 06:06 AM
DoRi2 2nDgEn fC's Avatar
GeeZer
this recently started happening.... like a couple days before 7stock... at 1st...my car would feel like its bogging out in 5th gear.. im not boosting or anything.... then it went away.... then all of a sudden... it started happening... 1,2,3,4,5 gear.... so i checked the timimg.... it was off by a quarter of an inch.... i fixed the timing thinking it was gone... and its still there... its bogging out every once in a while.... and when i slow down to stop... my rpms are at 1200... but when i put it into 1st gear... the rpms drop... anyone know why my car is bogging out when im in vacuum... not boosting... and y the rpms drop when i put it into 1st... its starting to get really annoying... i feel embarassed to drive it.. when it bogs out... PLEASE HELP.... hah but foreals..
Old Sep 22, 2004 | 06:23 AM
fastcars101's Avatar
could be a number of things.... check to see if you need your injectors cleaned.. might not be gettign enough fuel to the engine. depending on what mods you have you might need other things such as a fuel pump.. What mods are you running right now?
Old Sep 22, 2004 | 07:17 AM
SureShot's Avatar
Seduced by the DARK SIDE
I had random fuel cuts that gradually got worse.
Check out this short (fuzzy) video clip.
link to video
Each rev up was at WOT.
If you look close, you can see the boost gauge go to 0.
The fuel cuts were caused by a worn out TPS.
The TPS idle setting was perfect, but the resistor was badly worn at part throttle, so the ECU was getting bad readings & going nuts.
Old Sep 22, 2004 | 07:48 AM
Bukwild's Avatar
mine was doing the same thing and it was the injectors. PM sent
Old Sep 22, 2004 | 08:12 PM
GeeZer
its a stock swap.... just knn filter and sheepdog bOV... and stock piping with exhaust... thats all the mods i have...
Old Oct 11, 2004 | 01:42 PM
GeeZer
so happends to be that my fuel pump is bad... so thats whats causing my car to act all stupid... so yea
Old Oct 11, 2004 | 03:15 PM
SureShot's Avatar
Cool - not only did you find the problem, but you posted what you found.
Way to go..
Old Oct 11, 2004 | 03:52 PM
BlaCkPlaGUE's Avatar
I live in an igloo
Yea thanks, when someone else searches now they'll have an idea of what could be the problem.
Old Oct 11, 2004 | 04:12 PM
Icemark's Avatar
title edited... no profanity in thread titles
Old Oct 12, 2004 | 12:37 PM
GeeZer
sorry about that icemark... but yea its the fuel pump... im glad i didnt get the injectors rebuilt or buy new ones or anything...it wouldnt have been the problem... so yea... im pretty glad i saw it before ripping the motor apart... so yea... thanks for the help everybody...
Microtech
Aug 23, 2015 11:04 AM
smikels
Aug 18, 2015 01:26 PM
rx7brandon
Aug 16, 2015 10:55 AM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
