What does it take for Mid 12's?
Old Aug 29, 2004 | 06:23 PM
Terrh's Avatar
STUCK. I got SNOWNED!!!!!
Can it be done on the stock turbo?
My current mods:
3" DP/3" MP/3"Y/2.5" Dual/3" Straight mufflers
Intake/Cone Filter in cold air box
Boost gauge (lol)
S-AFC.
Solid engine mounts
Cheap-*** 10 year old goodyears, on stock wheels
Clutch that doesn't disengage properly when really hot
What else do I need to get there? I've got a fuel pump and injectors on the way.. then I need more fuel before I can get more boost..
I put crushed ice on the intercooler when at the track/whatever.. this seems to help alot. Do I need to go to a front mount/different IC?
Old Aug 29, 2004 | 06:28 PM
Terrh's Avatar
OHHH
I've also got (on the way, not yet) open-vented wastegate.. so my exhaust flow should be pretty damn good, I think.. I don't think that my exhaust will be a restriction EVER again.. not with a stockport 13b-t.
I'm getting the twin-scroll working again this weekend as well, because not having it = teh poop. the low end is SO WAY BETTER with it on, not in performance driving, just in regular putzing around.
Old Aug 29, 2004 | 07:23 PM
calio64's Avatar
you will need a better turbo for mid 12's, and yes you will need a fmic
probably going to need around 320-350 hp for mid 12's stock turbo is only good for like 275
Old Aug 29, 2004 | 07:42 PM
gsracer's Avatar
EIT
300rwhp with drag radials/slicks will be close.
Old Aug 29, 2004 | 07:45 PM
Turblown's Avatar
Turn up the boost
front mount/slicks and good driving.
Old Aug 29, 2004 | 08:07 PM
whtrice's Avatar
White Rice
87 turbo II with a turbo back racing beat exsaust, bosh fule pump, 10mm plug wires and nkg plugs, permacool e-fan, hks BOV, racing beat springs with tokiko shocks, and a new 13b from atkins with a full street port and 3mm apex seals, apexi intake, hks ground kit with 8 in wide volk gt0u rims get me to 12.9 at 105mph...
Old Aug 30, 2004 | 08:35 AM
Aaron Cake's Avatar
Engine, Not Motor
High compression turbo-NA @ 12PSI and a good launch...
Old Aug 30, 2004 | 09:20 AM
vrooom305's Avatar
woooo hooo....I already have the N/A! Now all I need is to invest in a $3000 - $5000 turbo setup
Old Aug 30, 2004 | 11:24 AM
Tessai's Avatar
What will I drive next?
Or, you could try this....
http://www.nopistons.com/forums/inde...howtopic=47434
Old Aug 30, 2004 | 11:55 AM
flamin-roids's Avatar
Lets rock.
How about to you take the TII motor out and drop it into a gutted 1st gen. I guarantee you will see 12's.
Old Aug 30, 2004 | 11:58 AM
1987RX7guy's Avatar
Eat Rice Don't Drive it.
BNR Stage 4?
Old Aug 30, 2004 | 04:07 PM
andrew lohaus's Avatar
a better clutch and tires are gona be a start.
Old Aug 30, 2004 | 04:51 PM
LookThatsMe's Avatar
def need a better clutch, flywheel, fmic, some stif shocks so u dont do wheel hoops, better turbos, get a external wastegate with a purge guarantee it will turn heads, and port out your intake manifold, and get some wide wheels with tires that have crazy glue on them lol
Old Aug 30, 2004 | 04:52 PM
and dont forget some weight reductions
Old Aug 30, 2004 | 07:44 PM
Terrh's Avatar
no weight reduction aside from easy stuff (hatch mat removal. spare, etc).
Better clutch is on the way when this one fails. not till then. I did it twice last year, and I'm not looking foreward to a 3rd time.
I guess I wasn't specific, but I want to be in the 12's with my 10AE
Old Aug 30, 2004 | 07:46 PM
Terrh's Avatar
a divided wastegate isn't really necessary with my setup.. it's open vented and seperate from the rest of the exhaust flow.. it's "almost" divided.
ls1swap
Jun 3, 2024 03:25 PM
He's On Toroids
NE RX-7 Forum
48
Oct 19, 2015 08:58 PM
joel(PA)
Oct 4, 2015 06:07 PM
