Does anyone use Redline Water-Wetter?
Old Aug 8, 2002 | 12:09 PM
ApexRX7's Avatar
the subject says it all...... anyone have good luck with this stuff? and what is the temp. on our stock thermostat? any recommendations for aftermarket thermostat temps?
Old Aug 8, 2002 | 12:25 PM
mjw's Avatar
mjw
I use water-wetter in all my cars, it didn't make a noticeable drop in water temps.. but it is good piece of mind, and helps lubricate the water pump.
Old Aug 8, 2002 | 12:39 PM
rynberg's Avatar
I use it. The added cost is small for additional protection.
Old Aug 8, 2002 | 12:53 PM
Hyperite's Avatar
Vagina Junction
180'F is the thermostat.
~Tom
Old Aug 8, 2002 | 01:34 PM
MastaCow's Avatar
My understanding is that WaterWetter doesn't contain any pump lube.
A friend of mine uses distilled water, a bottle of WaterWetter, and a bottle of water pump lube. No coolant.
Old Aug 8, 2002 | 01:54 PM
RonKMiller's Avatar
Blow up or win
Not according to the manufacturer: www.redlineoil.com.
I've used it for years and think it works well especially in hot climates like I live in (Tucson). You need to still run some anti-freeze with it (20%) since you can freeze your coolant even with 100F temps outside on the A/C condensor. Weird but true.
Old Aug 8, 2002 | 01:56 PM
RonKMiller's Avatar
Blow up or win
I guess www.Redlineoil.com is temporarily www.Offline.......It's a good site for future ref.
Old Aug 8, 2002 | 02:47 PM
GoRacer's Avatar
Speed Mach Go Go Go
I don't think it lowers the temerature, more like helps control the boiling boint like evans. This is just a guess but I haven't heard any bubbling since I used Royal Purple Ice.
Old Aug 8, 2002 | 03:20 PM
ErnieT's Avatar
Living life 9 seconds at a time
Some info you guys would be interested in. Ray Lochead as well as KD Rotary informed me that water wetter eats coolant seals. According to them it shortens you engine life by over half. When I heard that, I drained mine that moment!
Old Aug 8, 2002 | 03:23 PM
Street King's Avatar
*** Bless Texas!
Works very well, helps keep the temps controllable, not lower.
Old Aug 8, 2002 | 04:06 PM
skunks's Avatar
I'm a CF and poop smith
I have used it in 3 cars and have not seen any difference
Old Aug 8, 2002 | 04:29 PM
GoRacer's Avatar
Speed Mach Go Go Go
Question ErnieT
Did they mention anything about Royal Purple's version of Purple Ice?
Old Aug 8, 2002 | 04:35 PM
I have heard that from other sources as well.
Old Aug 8, 2002 | 04:58 PM
ErnieT's Avatar
Re: ErnieT
No, Only Water Wetter was mentioned.
Old Aug 8, 2002 | 05:05 PM
JonesersRX7's Avatar
I have heard this from a couple of forum members as well. Could be hear say.. but why risk it?
For the effort and expense, I would just use Evans.. just my $0.02
-- Eric
Old Aug 12, 2002 | 05:35 PM
GoRacer's Avatar
Speed Mach Go Go Go
Royal Purple Ice
Hi GoRacer,
No negative issues whatsoever concerning elastomer compatibility with Purple Ice in rotary and/ or piston engines.
Thank you,
Jared Martin
Royal Purple Ltd.
-----Original Message-----
Sent: Thursday, August 08, 2002 5:00 PM
To: jaredm@royalpurple.com
Subject: Purple Ice and rotary engine?
There is a topic on the RX-7 forum regarding Red Line's Water Wetter. I am currently using Royal Purple's Ice instead. Is there any harmful
effects to the coolant seals in a rotary engine?
Old Oct 30, 2003 | 06:01 PM
SERIES7's Avatar
Embassador to SOY
GoRacer, it's been over a year since your last post on this thread. have you come across any cooling issues sicne then? I know it's kind of an amiguous question, given the fact that anything could contribute to coolant seal failure. I have been soy'ching and I'm Just curious.
Shainiac
Jul 17, 2019 02:20 PM
gxl90rx7
Haltech Forum
Jun 30, 2017 11:30 PM
c0rpse
16
Sep 25, 2015 11:33 AM
