Running Denatured Alcohol?
Old Apr 7, 2002 | 02:32 PM
RXTASY1's Avatar
I have heard that if you run your tank down to almost empty, then add a gallon of denatured alcohol to it, will make you pass emissions guaranteed!
I guess the alcohol burns really hot and clean, yet your car runs.
Anybody tried this?
Old Apr 7, 2002 | 04:32 PM
peejay's Avatar
Old [Sch|F]ool
The alcohol makes the engine run leaner, since alcohol requires that it be injected in larger amounts to burn. It doesn't burn "hotter", and "cleaner" is debatable.
It will sorta work to make your car run leaner, if the reason it fails is because it's running too rich. If you're already running excellent, it could make you fail because you're running too lean.
Old Apr 7, 2002 | 11:28 PM
RXTASY1's Avatar
That's what I wanted to hear!
I'm running crazy rich right now!
Old Apr 19, 2002 | 12:56 AM
Actually, denatured alcohol burns COOLER and cleaner, not Hotter. Best method i've found is to mix 5 gallons of gas with 1 gallon of Alcohol. It's best to have as little gas in your tank as possible, preferably on 'E'. On your way to the smog station, stop somewhere and make about 5 or 6 Hard 1/4mi runs back in an Industrial Park to superheat your Cat, then drive Directly to the smog place while your Cat is still hot. The Alcohol reduces nox and co2 in your exhaust. I got a buddy of mine to pass smog with his sr20det this way. Try it, all you can do is Fail. Remember, pass or you dont pay
Old Apr 19, 2002 | 06:17 AM
Anthony Rodrigues's Avatar
I dont understand! Gas is crude base and Alcohol is water base fuel, they do not mix unless a quantity of aceton is added. How are you just mixing them together, or do you have differnt alcohol?
Anthony
Old Apr 20, 2002 | 03:13 AM
We didnt mix anything but gas and denatured alcohol (purchased from home depot)
Old Apr 23, 2002 | 11:17 AM
RXTASY1's Avatar
ttt
Old May 8, 2002 | 02:37 PM
RXTASY1's Avatar
TTT
Old May 8, 2002 | 05:16 PM
Crusader_9x's Avatar
hey i had a 86 gxl. the motor wasin **** condition. it overheated everytime i drove it and ran like ****. blah blah. but come emissions time it blew 600+ hc when athe legal here is like 180 or so. i ran my tank to empty and dumped in a gallon of denatured alcohol from home depot and it passed. now i didnt care about that car much at all so i didnt care\dont know if it did any harm. but i donot think that it did. so you should be good. the wayt i ssee it it will really clean everything out. rememer to fill up whenever you are done with the test
Old May 8, 2002 | 11:18 PM
Jade Falcon's Avatar
Ya Mama
I remember a looong time ago I heard that if you bathe a rat in denatured alcohol for three months it's 50% more likely to get cancer.
Thought you'd like to know that......
C. Ludwig
Jan 30, 2019 06:31 AM
Rotospectre
Mar 28, 2018 03:33 PM
The Shaolin
Sep 14, 2015 07:50 PM
86glxNA
Aug 22, 2015 08:54 PM
