Compressor map gurus - I've got the stock twins map!
Old Feb 2, 2006 | 10:24 PM
DaleClark's Avatar
RX-7 Bad Ass
Hey all -
Found this in RX-7 Magazine #20. I also have the full page scanned, but it's too large for a forum attachment and my web host is acting up right now (grr!). The full page shows pictorial differences between the 280hp twins and the 255hp twins.
Anyhow, this map looks decent enough to make some conclusions from hopefully. The maps from the 2 stock twins (hi/low power) are overlaid. I used to know how to read compressor maps, but that part of my brain is now rusty . Can anyone gather insight from this?
Dale
Attached Thumbnails Compressor map gurus - I've got the stock twins map!-twins_comp_maps.jpg
Old Feb 2, 2006 | 10:25 PM
t-von's Avatar
Rotor Head Extreme
WOW thx for this. Too bad there are no numbers for the pressure ratio and cfm.
Old Feb 2, 2006 | 10:28 PM
Indian's Avatar
It wasn't me!!
great find!!
rotariesrule's Avatar
excellent!
Old Feb 3, 2006 | 07:00 AM
Howard Coleman's Avatar
Racing Rotary Since 1983
amazing find Dale.
unfortunately without the flow data there are few conclusions that can be drawn. since the data had to be used to construct the map someone at mazda decided to titillate us, just give us a partial peak. now it is a question of finding the X line data.
since twins make somewhere around 380 or so rear wheel, and it takes approx 1.92 cfm to make a rw rotary hp, they probably flow 364 cfm tops which would put the max on the X line at 25 lbs/minute. if you were to post that in at the max line you could come up w the lefthand surgeline and anything in between since the x line is linear.
howard coleman
Old Feb 7, 2006 | 01:48 PM
neit_jnf's Avatar
380whp at what pressure ratio? 17 psi or 2.15 Pr? But what's the efficiency at this point?
Old Feb 7, 2006 | 06:35 PM
cptpain's Avatar
Torqueless Wonder
it would drop around 60-50% or less. if i read the map correctly...
Old Aug 12, 2013 | 10:45 AM
Iwan's Avatar
Wanted to share my newest finding on the topic (even the old one)
For everyone whom might be concerned, source is HIGH FLOW TURBOCHARGERS ‹ GCG
Best,
Iwan
Attached Thumbnails Compressor map gurus - I've got the stock twins map!-highflow_mazda_graf.jpg
C. Ludwig
Jan 30, 2019 06:31 AM
Skeese
65
Mar 28, 2017 03:30 PM
befarrer
Microtech
Aug 22, 2015 05:52 PM
ChrisRX8PR
Aug 21, 2015 01:56 PM
