what RPM should i drop the clutch
stupid question...but im curious to see what you N/A guys consider a good rpm to drop the clutch at a stop light? lets say your at the light and a honda with a fred durst wannabe pulls up? what RPM do you use for maxium launch. i have a vert, heavy, and a total pig on a hot day? BTW why do RX's suck so bad on a hot day?
need to get a electric fan or something.ok ..... lets see what you all say
Any car will suffer on a hot day. If you have a proper cold air intake and aren't sucking air from the engine bay it won't make any difference that it's a rotary.
As for launch rpm, that will be different for every car so it's no use getting other peoples opinions. Engine mods, suspension set-ups, tyre choice, etc will all have a huge impact. You need to find out what works best for your car. Basically you want to find the point that causes just a tiny bit of wheelspin. If it bogs you're too low, if it spins you're too high. Experiment.
yeah actually, any car will lose power on a hot day. It just seems to me that my rx-7 loses more power than my other car. Even if you have a cool air intake and everything the intake manifolds still heat up and the intake air will be very hot.
Yeah, ive noticed the intake manifolds do get really hot... saw this kid ricing out his civic this one night at the shop, was installing this rather thick plastic gasket between the manifold and the engine, it was supposed to keep the the manifold temps down... i wrote it off as rice, but what do you guys think, could something like that work?
Trending Topics
I'd assume that launching a vert is pretty similar to launching any other n/a...
7500RPM, let the clutch out quickly but not instantly.. take maybe 1/3 - 1/2 of a second letting the clutch out.
and I don't care how hot the intake manifold is, if air is taking less than 1/2 of a second to go from one end of the intake to the other, it's not going to get much heat from it.
I forget what those gaskets are called, but it seems like they're all the rage these days. They do help, but .. really aren't worth the $$$ and hassle unless you need every last pony possible, or if you've allready got your LIM off..
They are called pheno-spacers. Yes they help. My friend is actually trying to get them made for our FCs.
https://www.rx7club.com/forum/showth...hreadid=185631
Anyone interested should PM him and let him know. $100 really isnt expensive at all for a new mod..
oh ...so dont just drop the clutch.... let it off quickly but not suddenly. got it. no wonder i was smoking the tires and going no where fast. speaking of the intake temp.....why cant anyone out there make an all tube set up like they do for everyone elses car. i would like to get rid of that stock air tube in place of something better. can i use turbo pipes with the collars to fabricate something......or can i just buy a weapon r and modify it?
in nom technical terms you have to have that lame twisty straw intake tube because it connects to the air flow sensor right behind the air box. because the air flow rate and consequent fuel mapping are so important to preventing detonation (especialy on your TII) no one should mess with it unless they REALLY know what they are doing. thus the twistry straw stays because the air flow sensor does. as for the rest of it--just look at the fender well there is no where to snag cold air unlessyou drill a 4" hole in the sheet metal and take a pipe down under the headlights or in front of the radiator. so us poor fc's are stuck with a cone filter straped o to the air meter in place of the air box. alas.
Originally posted by andrew lohaus
in nom technical terms you have to have that because it connects to the air flow sensor right behind the air box.
DO NOT go with the Weapon R system. My friend bought one a few weeks ago for his MR2 (AW11), that filter is the worst thing I think we ever did to his car. The power was nearly non-existant, the sound was just louder but nothing good. Since my baby is sitting right now until I get the money to make those pretty tags on the back. Anyway I put my Bonez filter on his car and...WOW. HUGE difference, the car not only sings, but it's noticeably faster. The mileage is better, it's just better all the way around. Do yourself a favor and just get the filter (either Bonez, APEXi, or Blitz...all very great). If you can get/make a box...it'll be worth it. Just don't go with the Weapon R...you will regret it once you get a chance to use a real intake.
AXA
Sep 5, 2015 10:06 AM
