13b Gpm Of Pump?
Old Jan 14, 2004 | 09:34 AM
JAKE1's Avatar
13b Gpm Of Pump?
86 13B, WHAT GPM DOES THE STOCK FUEL PUMP MAKE. I HAVE TO RUN A EXTERNAL INLINE FUEL PUMP. I KNOW THE 13B PUMP PRODUCES 64-85 PSI, BUT WHAT GPM?
Old Jan 14, 2004 | 10:14 AM
Icemark's Avatar
2.28 to 3.44 gallons per minute.
But why are you doing an external pump??? There is no reason. Most external pumps can not reach the PSI that a in tank gas cooled pump will.
And your caps all on, means you are shouting. Stop shouting.
Old Jan 14, 2004 | 10:50 AM
JAKE1's Avatar
This is going in a rock buggy, so it has to be a external pump. That is a lot of GPM? I read in the 88 factory service manual it should be atleast 1.3 gpm. im not shure what it should be exactly, so i wanted to ask.
Old Jan 14, 2004 | 10:58 AM
Icemark's Avatar
Factory figure in the specs section of the shop manuals is in liters. I just converted.
Old Jan 14, 2004 | 11:14 AM
JAKE1's Avatar
The one I read said gpm in us gallons. I just called aertex, the manufacturers of fuel pumps. They told me the rx7 fuel pump has 60-95 psi with 55gph which is .92 gpm.
Old Jan 14, 2004 | 11:29 AM
Icemark's Avatar
Sounds like the specs for their replacement part has those specs.
As the Mazda factory specs for the fuel pump for PSI are 71.1 to 92.4 with a feed capacity of 2200 to 3300 cc/Min
Old Jan 14, 2004 | 11:41 AM
slow87turbo's Avatar
OH,YOU TOUCHED MY TRALALA
so do you think a good mod would be a 3rd gen fuel pump in a 2nd gen along with a safc and 720cc secondaries.
ej
Old Jan 14, 2004 | 01:02 PM
truespin88's Avatar
truespin, not tirespin
Note to new users: Never argue with Icemark. Ever. You're wrong, and he's right.
Old Jan 14, 2004 | 03:37 PM
1987RX7guy's Avatar
Eat Rice Don't Drive it.
Are you sure you converted that right?
When I remembered that the Walbro 255 is in Ltr/H which is liters per hour. Now there are 3.8 liters per gallon so we can translate 255 ltr.h to 67.1 gal/h(gallons per hour) take that and divide by 60 to get the gal/m(gallons per minute) and you get 1.118 << now you said the stock pump is 2.28-3.44 gpm how can the Walbro 255 be an upgrade if its way lower in gpm than stock?
Sorry but I might be completly wrong but I just wanted to ask. Sorry if I made a noob mistake somewhere in the math.
Santiago
Thanks in advance Mark.
Old Jan 14, 2004 | 04:45 PM
Icemark's Avatar
well lets see... 2200 cc/min is equal to .57 US quart/min.. so yep I did my math wrong. Multipled when I should have divided.
Icemark's Avatar
See sometimes I am barking out my ***
Old Jan 14, 2004 | 04:47 PM
1987RX7guy's Avatar
wooo hooo! So my math for the walbro was ok right? whats the real gpm and gph for the stock pump then?
Old Jan 14, 2004 | 04:51 PM
Icemark's Avatar
Old Jan 14, 2004 | 04:58 PM
1987RX7guy's Avatar
Ok then 1cc= 0.001 L
then I took the median of 2200 and 3300 which is 2750cc's and divided by 1k which is 2.75 then divided by 3.8 which is 0.723 gpm woot! If thats wrong let us know guys.
Santiago
Old Jan 14, 2004 | 05:51 PM
RETed's Avatar
FC turbo is like a little over 50gph.
FC non-turbo is more like 40gph.
Divide by 60 to get gpm.
These numbers shouldn't be over 1.0!
-Ted
Old Jan 17, 2004 | 10:48 AM
JAKE1's Avatar
SO FINAL ANSWER IS .723, .92 OR 1.3 GPM? I SEE HERE ITS ANYWHERE BETWEEN .723 TO 1.3 GPM. THE BEST INLINE FUEL PUMP I CAN FIND IS .67 GPM AT 70-95 PSI. IF THE 13B IS .72 AT 65-95 PSI,
WHAT PROBLEMS WILL I HAVE WITH THE SMALLER GPM?
DOES ANYONE KNOW OF A INLINE PUMP THAT PRODUCES THE 13B'S REQUIRED #'S?
SORRY ABOUT THE CAPS, IM NOT YELLING!
Old Jan 17, 2004 | 01:37 PM
1987RX7guy's Avatar
The figure I stated should be the average gpm for the stock pump. In my personal view I wouldn't opt for a lesser gpm pump. It can only creat problems by leaning out.
Santiago
Old Jan 17, 2004 | 06:58 PM
I wish I was driving!
Don't run a smaller pump.
Aeromotive makes inline pumps that flow 1.4-1.8GPM.
Your project is stupid. Rock crawlers need the bottom end torque of a piston engine. A rotary has NO bottom end torque. Your project will fail.
Old Jan 17, 2004 | 07:59 PM
RETed's Avatar
Are you stupid?
Why are you trying to run a SMALLER fuel pump than stock???
Are you going to convert to carbs or something?
USED NA fuel pumps are cheap and plentiful.
Why are you so stubborn about getting an aftermarket one?
You can get a Walbro 190lph fuel pump for under $100.
-Ted
Old Jan 18, 2004 | 12:27 AM
JAKE1's Avatar
Post edited for flaming!
Old Jan 18, 2004 | 12:34 AM
Well, if you knew anything about cars, you could easily have found an inline pump.
Its obvious you have no clue what you're doing. no matter what gears you use, rock crawling with a rotary is going to be a failing event (though it'll be funny as hell hearing a rotary at 7000 rpm in a vehicle moving 3mph [as a result of your compensated gearing]).
Quick question: how old are you and how many chassis have you built in total for any competition use?
Old Jan 18, 2004 | 12:51 AM
JAKE1's Avatar
IM 28 YEARS OLD, HAVE BUILT 14 CHASSIS, MY CURRENT ONE IS ON THIS MONTHS COVER OF 4 WHEEL & OFFROAD MAGAZINE AND I AM RANKED THIRD IN THE NATION AS A ROCK CRAWLING COMPETITOR. DA! I KNOW WHAT IM DOING!
Old Jan 18, 2004 | 02:09 AM
Icemark's Avatar
Thread edited and closed for flaming and post ******
rotor_veux
Sep 3, 2015 07:10 PM
tonka_1956
Sep 2, 2015 05:55 PM
