diffrence between N326 and N327 ECU's
Old Aug 15, 2004 | 04:29 PM
felixwankel88's Avatar
Hey
Whats the diffrence between N326 and N327 ECU's are they interchangabel
Please let me know
thanx
Dustin
Old Aug 15, 2004 | 04:50 PM
tong53's Avatar
satan lives in my car
they are interchangleable. as to the differences i dont think there are any but feel free to correct me if i am wrong.
Old Aug 15, 2004 | 04:52 PM
if there the same interchangabe then why do they have diffrent numbers(diffrent years) if someone could explain it in more detail that would be great
Thax in advance
Dustin
Old Aug 15, 2004 | 05:29 PM
Bummmmmp Helpppppppppppp
Old Aug 15, 2004 | 05:34 PM
tong53's Avatar
ECU Part Numbers (this is the version # that's on the ECU itself)
84-85 GSL-SE N304 18 880A
86-87 NA N326 18 880, N3Y6 18 880
87 Turbo N332 18 880
88 NA N327 18 880
88 Turbo N333 18 880
88 Convertible N338 18 880
89 NA California N350 18 880
89 NA Fed. N351 18 880
89 Conv. CA N352 18 880
89 Conv. Fed. N353 18 880
89 Turbo N370 18 880
as found at http://www.rotaryresurrection.com/
so yes different years
as long as the first 3 parts are the same then they will be interchangeable. n32x will work as long as its replacing n32x
Old Aug 15, 2004 | 06:30 PM
Kai's Avatar
Kai
Rotorphile.
There is no significant difference, only a few minor fuel and timing tweaks most likely for emissions reasons.
Old Aug 15, 2004 | 09:56 PM
1987RX7guy's Avatar
Eat Rice Don't Drive it.
^ he's got it.
Old Aug 16, 2004 | 04:07 AM
RETed's Avatar
One is for 1986 models and the other is 1987 models.
DUH
Old Aug 16, 2004 | 06:31 PM
rxspeed87's Avatar
RETed wouldn't it be
some are for 86-87 while the other ECU is for 87-88?
Old Aug 16, 2004 | 08:18 PM
RETed's Avatar
According to the Mazda parts fiche, the split is for the years.
-Ted
Old Aug 16, 2004 | 09:48 PM
rxspeed87's Avatar
though I am kinda curious about mine
have an 87 the ecu is the 326 have a 327 boost sensor
has the early 86 style injectors
any idea why the 327 boost sensor is there? and that is the sensor that doesn't need all the extra grounding and stuff right
Old Aug 16, 2004 | 10:00 PM
inflatablepets's Avatar
I thought it was for California models or somthing like that.
Old Aug 16, 2004 | 10:36 PM
nonameo's Avatar
**-P I drive a miata.
I think it may have something to do with the injectors being low/high impedence
Old Aug 17, 2004 | 03:52 AM
RETed's Avatar
Again for the _&$@_%^^(*$@^&_&#@%_&@ time, the ECU does NOT care if the fuel injectors are high or low.
-Ted
Old Aug 17, 2004 | 11:40 AM
nonameo's Avatar
-Ted
jeez... thats why I said "I think" instead of "I know"... I wasn't quite sure.
Old Aug 17, 2004 | 12:57 PM
RETed's Avatar
If you wasn't quite sure, you shouldn't be posting in the first place.
-Ted
Old Aug 17, 2004 | 09:59 PM
Nevermind, I had a change of thought.
Erosangel
Sep 18, 2015 10:28 PM
Erosangel
Sep 18, 2015 04:06 PM
