just a quick question. what is this?
Old Dec 17, 2006 | 05:34 PM
xxpezzxx's Avatar
Team Inertia
near the starter, on the firewall. its on a 89 t2 thanx
Old Dec 17, 2006 | 06:30 PM
1987mazdarx7's Avatar
wide open all the way
i had the same thing i figured it might have been some type of ground of some sort. any body else?
Old Dec 17, 2006 | 06:36 PM
patman's Avatar
Resident Know-it-All
that is the capacitor (condenser per fsm) for the oil pressure guage. basically it just smoothes out the signal and keeps the needle from wiggling. you can toss it if you want, it has no real effect on anything.
Old Dec 17, 2006 | 06:38 PM
xxpezzxx's Avatar
Team Inertia
ok thanx
Old Dec 17, 2006 | 07:00 PM
would that be why my oil pressure gage is going wierd and says i have no pressure?
Old Dec 17, 2006 | 07:13 PM
patman's Avatar
very doubtful. Ive never seen one that actually changed the reading, it just mellows out the needle a little bit. chances are the wire is pulled off the sending unit, those clips suck, and thats a common wire to accidently knock off if you change plugs or anything.
its the little round thing maybe 2" in diameter that sticks out of the block under the oil filter. it just has 1 wire going to it, i believe its yellow/red, with a funky clip on the end.
Old Dec 17, 2006 | 07:15 PM
thanks man i will check tomorrow.
Old Dec 18, 2006 | 07:21 AM
My5ABaby's Avatar
Rotaries confuse me
I wouldn't toss it. From what I've heard it keeps the gauge from breaking due to random electrical surges or something like that. I'm not sure why you would just throw off a part. Hell, who needs an alternator?
Logan Reinisch
44
Sep 17, 2018 12:20 PM
zyph3r
Canadian Forum
Sep 16, 2018 07:14 PM
vish86
Interior / Exterior / Audio
Oct 1, 2015 11:53 PM
TeamRuffRacing
Sep 30, 2015 08:13 PM
