Thread size/pitch for garrett gt35r
Hi!
I wanna change my AN fittings to banjo bolts since its almost impossible to tighten AN.. Does anyone know the size and pitch on the oil in/out and water in/out fittings on a Garrett GT35R turbo?
I have googled it, but didnt find anything...
Sindre
Sindre
Engine, Not Motor
AN fittings are easy to tighten with the correct wrench. I got a standard flare nut wrench and then trimmed the end until it was a little less then a half hexagon. Works great in tight areas.
Accordint to ATP turbo, the water fittings are 14MM:
http://www.atpturbo.com/Merchant2/me...gory_Code=GTBB
The oil inlet is 12MM:
