reted's parallel fuel rail diagram?
Old Aug 13, 2003 | 07:52 AM
DCmaestro's Avatar
http://fc3s-pro.com/TECH/MODS/FUEL/fpr.htm
Does anyone have this page cached? I am about to buy all of the hose/fittings to do this and want to make sure I am going about it the right way. If not, I'll post my ideas on what hose/fittings to use tonight. BTW I have already checked the Way Back Machine at archive.org.
Old Aug 13, 2003 | 11:04 AM
Spawn VII's Avatar
you're one lucky man, i just happened to have saved the diagram way back one day when i was bored
Old Aug 13, 2003 | 02:04 PM
HAILERS's Avatar
HAILERS
DCmaestro
Are you interested in buying any of those fittings/regulators? Brand new? Heavy, heavy discount. I have most of those parts and just decided not to do it myself.
Old Aug 13, 2003 | 10:43 PM
DCmaestro's Avatar
check your pm's
Old Aug 14, 2003 | 12:50 AM
silverrotor's Avatar
This Is the one thing of value, at this particular time, that I needed of RETed's site. I have the write up but now I've got the pic. Kudos Spawn VII!
Old Aug 14, 2003 | 12:54 AM
Spawn VII, perhaps you could Inform RETed about the pic so he can reincorporate It back Into his site.
Old Aug 15, 2003 | 09:33 AM
hay can i get the write up from you?
Old Aug 15, 2003 | 11:24 AM
HAILERS's Avatar
HAILERS
Here's the part numbers to go with the diagram above. Parts can be bought from SummitRacings catalog. Online.
Go to http://www.summitracing.com/ and type in the parts that follow to see what I paid.
AEI- 13109 FUEL PRESSURE REG 131.95
MORO-65160 FUEL BLOCK 22.95
EAR-991954 UNION, THREE, 5.95 ea
EAR-991945 UNION, THREE, 6.95 ea
NOS-17835 Y-BLOCK 29.95
Old Aug 15, 2003 | 02:04 PM
banzaitoyota's Avatar
What Subscription?
Thsnkd Hailers!!!!!
Old Aug 15, 2003 | 02:45 PM
1987RX7guy's Avatar
Eat Rice Don't Drive it.
So this helps maintain pressure in the fuel system? what other benefits are there to doing this?
Old Aug 15, 2003 | 02:46 PM
Rizla+'s Avatar
Sorry for the "stupid" question but I want to learn.
What is the main purpose of such a setup ?
Old Aug 15, 2003 | 03:00 PM
ponykiller's Avatar
having a rising rate fuel pressur regulator that you can set the static pressure on. When you start upgrading turbos, you need to do this to get the most consistant fuel flow from your injectors.
Old Aug 15, 2003 | 03:25 PM
rx7_turbo2's Avatar
Professor D.P
You gain a far superior fuel pressure regulator. And running the rails in parallel means there should be no drop in the primary fuel rail pressure when the secondary injectors turn on.
Old Aug 21, 2003 | 09:25 PM
TulsaTurbo's Avatar
Who sells the following:
-6AN to M12 x 1.25 adapter
-6AN to M14 x 1.5 adapter
Old Sep 3, 2003 | 05:52 PM
SnowmanSteiner's Avatar
Ga-nome liberator
Does anybody know how much line you need to do this, if you are planning on replacing it all? Also in reading some of this I got very confused, and was hoping someone could set me straight. With this setup you can elliminate the PD without risking harm to the engine correct? Assuming that you have either a rewired fuel pump or an aftermarket one correct. Please let me know where I am wrong and right on all this thank you.
- Steiner
Old Sep 3, 2003 | 07:16 PM
rx7passion's Avatar
summit (can) get these but it took me 3 trys cause they kept sending me the wrong parts even though i told them exactly what i wanted.
amount of hose? i got a 10ft chunk and it was more than enough. pulsation dampener? it will be gone if you do this setup. and fuel pump most people that spend the money to do this setup buy a high flow fuel pump.
Old Sep 3, 2003 | 07:50 PM
Crusader_9x's Avatar
when going parallel and adding all of those an fittings and what not, where do u put them on the rails? on the stock in and out places or do u cut off the ends of the rails and tap them and screw them in there?
Old Sep 3, 2003 | 08:29 PM
think i may try this out
Old Sep 3, 2003 | 08:34 PM
I wish I was driving!
Remove the stock banjo bolts. The listed adapters fit in their place, and allow the use of AN lines.
Old Sep 3, 2003 | 08:50 PM
so what part of those unscrew? cuz it looks and feels like a solid piece to me.
Old Sep 3, 2003 | 11:31 PM
Ridge Tech's Avatar
ok that is a custom rail some one had made, but as you can see here, thought he power of MS paint and my 5 sec's of work, i've brought you this master peice pointing out where the different parts of the rail would unbolt.
Chris
Old Sep 4, 2003 | 07:27 AM
well if thats a custom rail then i got 2 of them one set that came on the car and oneset in one of the spre part bins. so i cant do **** with my rails then?
Old Sep 4, 2003 | 10:22 AM
rx7passion's Avatar
if you really want to do this setup grab a set of rails from a 86-88 t2. ive got a set but i dont wanna part with them
Old Sep 4, 2003 | 10:27 AM
Icemark's Avatar
That is a series 5 rail. You would need to convert to a series 4 rail to do the set up ted is talking about.
Old Sep 4, 2003 | 10:31 AM
Ridge Tech's Avatar
I've got a S4 TII I guess thats why it looked forigen to me. Are they Alum. like the S4's?
