Drifting Discuss Drifting and drifting techniques here.
Drift car build
Old Apr 29, 2012 | 11:55 AM
quick.msp's Avatar
Gearhead
Drift car build
Ok so my car is finally getting somewhere and I just wanted some opinions that have done this before.
The car is a fc3s with a ls1/t56 in it. The t-56 is being built right now and Im currently working on all the body work.
I have the whole interior stripped read for primer, the interior harness has all been gutted so I only have what I need, also just took the dash out.
questions
1. I have seen people cut the rear strut covers off, what is the cleanest and easiest way to do this?
2. When I removed the dash, the big as unit along with the heater core I believe is there mounted to the firewall. Can I remove the white AC unit and still have heat?
Just making sure im doing everything ok, I stripped everything and got it down to bare metal. I bought Duplicolor primer (not spray can I have a spray gun) and was going to do three coats primer then three coats automotive paint.
Also I have the headliner out and have no clue what to do with the roof, id like to keep it gutted and maybe throw some paint, car does have sunroof.
Thanks,
I appreciate the help.
Old Apr 30, 2012 | 05:40 PM
quick.msp's Avatar
Gearhead
annyyyyonnnneeee
Old Apr 30, 2012 | 08:12 PM
I fc3SLIDE's Avatar
i use at spot weld drill bit and drill out the spot welds and use a hammer and big flathead mine came out nice sometimes youll need to cut the majority away to get to the back couple of spot welds
bb6guy
Old School and Other Rotary
Oct 1, 2018 08:07 AM
rotor_veux
46
Jun 12, 2018 10:39 AM
dkwasherexd
May 27, 2017 04:51 AM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
