Bushing in the transmission mount brace
Old Mar 16, 2012 | 02:01 PM
DeaconBlue's Avatar
Living on the North Coast
Since my car is still street legal, rather than go with solid bushings, I went with a full set of Mazda competition rubber mounts for the transmission and differential. The question that I had was the bushing in the transmission mount brace.
Would it make any sense to fill the voids in this bushing with say 55 durometer polyurethane window adhesive?
http://solutions.3m.com/wps/portal/3...beQH8HT14PGTgl
I have used this material in the past on several other vehicles to fill in the voids in rubber bushings (both suspension and mount) that were designed primarily with compliance and NHV in mind and not true/full containment.
TIA.
Old Mar 20, 2012 | 04:20 PM
DeaconBlue's Avatar
Over a hundred views and no comments. So either I am being way too **** and worrying about something that doesn't need to be done or I came up with something no one else had thought of before. I tend to think it is more likely the former than the latter.
Old Mar 20, 2012 | 04:50 PM
jgrewe's Avatar
GET OFF MY LAWN
Sounds like a good idea, I used to pound nails into the motor mounts on my first VW Rabbit racecar.
Old Mar 20, 2012 | 07:36 PM
wlfpkrcn's Avatar
Did you have them attached to a string in the cockpit?
Hey that guys is closing in. better drop a couple nails on the track
Old Mar 20, 2012 | 07:46 PM
jgrewe's Avatar
GET OFF MY LAWN
No, but I did use the parking brake lever to adjust the rear sway bar...(not legal) Having the nails to release would imply that I thought I would be out front
Old Mar 22, 2012 | 02:19 PM
eage8's Avatar
1308ccs of awesome
after replacing the two tranmission mounts with mazdacomp mounts, I don't think that bushing is going to get much load on it... it's probably not worth it.
Old Mar 23, 2012 | 06:05 PM
BLUE TII's Avatar
Rotary Motoring
I say fill it or punch the metal sleeve out tearing the rubber tabs and press in a metal sleeve that fits with no voids.
I don't know how, but even with full Mazdacomp mounts on the car that transmission mount still breaks off the rubber connecting the steel sleeve to the bushing and the giant washer with rubber pad under the trans mount gets all bendy.
Old Mar 23, 2012 | 06:21 PM
just startn's Avatar
Turbo vert
Hmm, you have me thinking. See what i can come up with.
Old Mar 23, 2012 | 09:36 PM
Turbo vert
I just made something after reading this. Uploading photos now. (idk if you can already buy this mount aftermarket).
Old Mar 23, 2012 | 10:53 PM
Turbo vert
The way it sat when removed from transmission
Clean off old rubber on spacer
Pressed in
think im going to make some sort of a rubber spacer to take the space up so the bushing cannot slide up.
Old Mar 25, 2012 | 11:39 AM
Turbo vert
Deacon, lmk what you think. your only right down the street and can have a poly mount for dirt cheap.
Old Mar 26, 2012 | 10:08 AM
DeaconBlue's Avatar
That is a very cool idea. I should have my new mount brace this week. When it comes in I will send you a PM. Thanks.
Old Jun 19, 2012 | 08:52 AM
rotaryB-2000's Avatar
Psalms 37**25
very nice work!
BNR34RB26DETT
42
Feb 28, 2018 11:27 AM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
