engine cuts after 1/4 thottle please help its been a year!
Old Feb 23, 2012 | 02:23 AM
sideways_fc's Avatar
I have a 94 rx7 all it has is intake front mount bov
so car can idle but its high everytime i press more than 1/4 thottle the motor cuts untill the rpms comes back down seems like if i throttle less than that it can go through the rpms please help been. Stuck for a year on this problem!! Any help would be appreciated thanks
Old Feb 23, 2012 | 08:01 AM
DaleClark's Avatar
RX-7 Bad Ass
What have you tried to fix the problem so far?
Does it do it just revving the motor in neutral? If so, it's just a fundamental problem with spark or fuel.
Any ECU codes? Have you changed the spark plugs? Changed the fuel filter? Fuel pressure good?
Dale
Old Feb 23, 2012 | 08:53 AM
theorie's Avatar
AponOUT!?
TPS sensor?
Old Feb 23, 2012 | 12:21 PM
Mahjik's Avatar
Mr. Links
First, read this thread:
https://www.rx7club.com/3rd-generation-specific-1993-2002-16/how-get-best-use-forum-911608/
You simply aren't providing enough information for anyone to be able to assist you. From the thread above:
* Post the history of the car. When did the problem start? Has the problem been this way since you got the car?
* Post how you noticed the problem. What were you doing when you noticed the problem?
* Post what modifications have been done to the car. The more complete information you provide up front, the quicker someone can provide good assistance.
Old Feb 23, 2012 | 07:14 PM
Radial GT's Avatar
*BOV sound*
Need more info for sure!
I was having this problem right after I wired in my FJO driver for the secondaries incorrectly. Anytime I went over 30% the engine would cut terribly. Found the error in my ways, and it has been fine since.
Old Feb 24, 2012 | 03:32 PM
It does it in netral or in gear i just pulled the codes i believe its 23 28 30 33 45 ive try'd 2 differnt tps both cant get into range prolly because i dnt warm it up spark plugs and wires are brand new. Also new fuel filter I bought the motor off a member of this site it was missing a few things like injectors waterpump alternator so bout all the parts did the simplified seq mod started it been trying to trouble shoot ever since
Old Feb 24, 2012 | 03:37 PM
Cars only mods are downpipe front mount bov light pullys no air pump simple seq mod
Old Feb 24, 2012 | 04:20 PM
theorie's Avatar
AponOUT!?
For the love of god, please speak in complete, sentences. At least try to use some punctuation - periods, commas, etc. No run-on sentences either - think before you type!
There are people who would be able to help you if they could just understand you...Here...I'll translate your post into non-retard English, maybe someone can help now:
Translation: The engine cuts out after 1/4 throttle whether the car is in neutral or in gear.
Translation: I've pulled the engine codes and it has reported: 23, 28, 30, 33, and 45.
Translation: I have tried two different TPS units but it is not reporting the correct voltage. Would this be because I did not give the engine time to warm up?
Translation: The car has new spark plugs, wires, and a recently replaced fuel filter. I bought this motor from another rx7club forum member but it was missing some parts, such as fuel injectors, the waterpump, and an alternator.
Translation: I bought and installed the missing parts and also performed the "Simplified-Sequential mod. Since I have installed the motor and performed these modifications, I have experienced the problem with the cutout after 1/4 throttle.
Now, all that aside. It sounds to me like the problem is your TPS sensor, as I suggested before. Can you give us the readings when the throttle is all the way closed and all the way open? If you have a Power FC you can follow this guide: http://www.westpennmazdaclub.com/fil...%20FD%20RX.pdf
Another thing that might be helpful to check: Are the fuel injectors OK? Did you buy them new or used? If used, did you have them flow tested first?
Old Feb 24, 2012 | 04:34 PM
Mahjik's Avatar
Mr. Links
23 Fuel thermosensor
28 Solenoid valve - EGR
30 Solenoid valve - split air bypass
33 Solenoid valve - port air bypass
45 Solenoid valve - charge control
IIRC, 23 will put the car into limp mode with the stock ECU. Do you have a fuel thermosensor connected? Have you check the wiring?
Old Feb 24, 2012 | 05:34 PM
I thought the fuel thermo sensor would throw the car into limp mode. Does anybody have a picture or wire diagram of the fuel thermosensor?? And i just relized when i did the simple seq mod i didnt put any resistors would that throw the car into limp mode Any help would be great.
On the other hand sorry for the typeing im useing a cell phone and im at work. Just rying to get some insite before i get home and start on it...
Old Feb 24, 2012 | 06:06 PM
Mahjik's Avatar
Mr. Links
The fuel thermosensor is on the fuel rail (green sensor in the picture below). As for the others, the "45 Solenoid valve - charge control" would be only possible one of that bunch which may cause an issue; the other three would be fine to leave as is...
Attached Thumbnails engine cuts after 1/4 thottle please help its been a year!-dscf0937.jpg
Old Feb 25, 2012 | 02:51 PM
Thank you so much for the info/picture im going to try fix it monday.
Old Mar 19, 2012 | 03:25 PM
Law's Avatar
Law
So how's it looking on your car? Did you fix your issue?
alphawolff
Nov 17, 2015 05:57 PM
smikels
Aug 18, 2015 01:26 PM
