fc lim >adapter>fd uim bolt length urgent
Old Feb 1, 2012 | 12:06 PM
no_luck's Avatar
does any one know the bolt length im in the store far from my garage
and i dont kno the length or the pitch
can some one please tell me asap
Old Feb 1, 2012 | 12:30 PM
misterstyx69's Avatar
Retired Moderator, RIP
Sorry ..Trick question.
How think is the Spacer?
How I Measured was to throw a piece of Threaded Metric rod through the holes and screw it in..grab that piece and mark it with the measurement(tape it.use a marker,whatever) and get the bolt required.
Old Feb 1, 2012 | 12:31 PM
The thread is the same on all the upper manifold bolts.so if you need to just grab a nut from one of the lower manifold studs...
Oh ya,you will need those Studs extended TOO..so they can hold everything together.
Old Feb 1, 2012 | 12:33 PM
no_luck's Avatar
damn... i guess ill have to go to the garage and measure.. or ill just buy 2 or 3 inch bolts and wish for the best.. aw crap i still gata figure out the thread pitch.. to the garge i go .. thanks misty
Old Feb 1, 2012 | 12:43 PM
it is over 4 inches long..
LOOK at the old bolt that was in there..add the spacer thickness and you get an idea.
I thought 110mm X .8metric...that is ROUGHLY
Old Feb 1, 2012 | 01:01 PM
no_luck's Avatar
i just got the manifold with out bolts or anything so i honestly dont kno.. ill just get the bolts some other time if worst comes to worst i cant make it back in time
Old Feb 1, 2012 | 05:09 PM
no_luck's Avatar
Yo misty your the man 110 m8 x 1.25 my threads were dirty so I had to clean them with a tap. So now I gatta get the 5 other bolts... I might start the car today if I can do everything befor it gets late.
I accidently got trans line instead of fuel line I hope it holds enough to start the car and. I hope that my fuel pump wornt turn on cause I didn't connect some wire or something
Old Feb 1, 2012 | 05:37 PM
That line needs to hold 40-50 PSI so it better be rated as such or it will burst.(<<<WARNING!)
HI pressure fuel line(the rubber stuff) is a little expensive but it works and holds the pressure of the Fuel system fine.
Old Feb 2, 2012 | 01:43 PM
no_luck's Avatar
i think its says reinforced trans cooler line i forget but i confused it because A it was labled wrong and B it have the strands of string in it.. ill just get some fuel line later this week.
sooo as of right now i just have to figure out the wiring and i should be able to start her up
toplessFC3Sman
Mar 20, 2018 01:54 PM
Monsterbox
Sep 11, 2015 03:29 PM
