best port for GT35R T3 1.06
Old Jan 21, 2012 | 07:24 PM
KrisD1's Avatar
Need your advice on what would be the best port to use with my GT35R T3 1.06.
The car will mostly be used on the Ring, you know the one in Germany.
Will need as much midrange power as possible, with a nice torque curve.
Old Jan 21, 2012 | 09:06 PM
Turblown's Avatar
Turn up the boost
Stock Ports.
Rotary Performance Parts
Old Jan 21, 2012 | 09:58 PM
Iwan's Avatar
Originally Posted by turblown
stock ports.
+1
Old Jan 21, 2012 | 10:48 PM
lastphaseofthis's Avatar
My job is to blow **** up
*choke*
Old Jan 22, 2012 | 01:22 AM
RexRyder's Avatar
Originally Posted by lastphaseofthis
*choke*
Didnt someone around here make 500+ rwhp with this thing on stock motor? Seems like good mid-range to me.
Old Jan 22, 2012 | 01:43 AM
silverfdturbo6port's Avatar
500+hp club
yup turbor1 did tuned by enzoracing. made 501 at i think 22psi but i could be mistaken. the videos of his red fd are all over the tube
Old Jan 22, 2012 | 11:30 AM
withdrawn.. i missed the mid range part. that t3 would be better for spool anyways.
Old Jan 22, 2012 | 12:43 PM
Turblown's Avatar
Turn up the boost
The only difference between a t3 and t4 gt35r is the flange. Volutes are the same.
Old Jan 22, 2012 | 02:17 PM
KrisD1's Avatar
Thanks guys, will go with a stock port then and If I need some more power I'll run some E85 and up the boost :-)
Old Jan 22, 2012 | 07:21 PM
Zero R's Avatar
Just in time to die
(Not picking a fight just making sure others know) The T4 1.06 divided housings are full T4 volutes. I initially had them cast through George at ATP years ago. The undivided "T4 inlet" housings that come in .8 A/r are the ones with the T3 volute.
OP, if you have to run the T3 frame 1.06 and are looking to get the most out of your ports I would suggest cleaning up the closing edge of the primary ports on the intake, (remove the lip). On the exhaust port match the sides to the sleeve and only port the bevel off of the bottom. You will see nice improvements with this with no noticeable losses. If you wish to be even more conservative just remove the bevel off the sides.
Your biggest issue will be heat using a 62mm discharge and a T3 volute, you can get away from some of this with 3.5" DP and either a very well placed single gate or dual gates at the first bend on the manifold. But I wouldn't be too surprised at how hot everything will get running that turbine on a track. You would be much better off with a step up to the next size.
~S~
Old Jan 22, 2012 | 08:37 PM
schaft's Avatar
This is the same turbo and porting I'm planing on using good to know there's good power in it.
Old Jan 22, 2012 | 10:23 PM
500+hp club
~S~
I agree 100% I port my cars that way and it delivers great low and mid power
Old Jan 22, 2012 | 11:18 PM
rx71king's Avatar
the diabolical one
..all ears...
Old Jan 23, 2012 | 04:46 AM
glenn's Avatar
~S~
Is it only your T4 divided housings that are full T4 volutes? I was about to order one from ATP but there is no point if they are just T3 with a T4 flange.
Can you sell me one of your housings if this is the case?
Old Jan 23, 2012 | 09:33 AM
Zero R's Avatar
Just in time to die
No, at this point Garrett has made them available through them now as well. If you already have a 35R then you can get it through ATP, Elliot, me, whoever. If you don't already have a 35R I would suggest something with a larger turbine discharge on a track car. You can offset the loss in response by running a tighter A/r. Ideally in most cases it is better to run a larger discharge and smaller A/r as opposed to a smaller discharge with a larger A/r.
~S~
bigtuna
Oct 8, 2015 10:01 PM
iamsisyphus
Sep 27, 2015 01:42 PM
josef 91 vert
14
Sep 17, 2015 09:22 PM
Clacor
Sep 11, 2015 08:36 PM
