Power Steering?
Old Jul 21, 2002 | 01:03 PM
zaridar's Avatar
35r 13b first gen
Power Steering?
I just started working on my 7 and im a little new to the car. I was wondering if it has power steering and if it does where is the fluid resivoir. Its a 1985 gs 12a.
thanks
Old Jul 21, 2002 | 02:46 PM
smnc's Avatar
EliteHardcoreCannuckSquad
It might or might not has PS. It was an option on the car.
Real easy way to tell if it's a PS car will be the PS resevoir right next to the steering column. Don't get it confused with the cluch and brake fluid reseviors tho.
Old Jul 21, 2002 | 04:10 PM
peejay's Avatar
Old [Sch|F]ool
A PS car mounts the PS pump down low and the A/C compressor above that - it's so high that the A/C lines physically rub on the hood.
A non-PS car has the A/C compressor down low.
The P/S dipstick is at the back of the pump - you have to dig down under the spark plug wires to get to it.
Allegedly only GSL and GSL-SE could have P/S, but early on in my RX-7 life I looked at an '84 GS with power steering.
Old Jul 22, 2002 | 12:28 AM
zaridar's Avatar
35r 13b first gen
thanks for you you guys' help!!
Old Jul 22, 2002 | 12:38 AM
Spieder's Avatar
Easiest way to tell and you don't have to open the hood. With the car running turn the steering wheel from side to side at rest. Now, turn the car off and do it again. If you have PS it will turn like a bitch with the engine off and smooth with engine on. If you don't, it will turn the same on or off.
It's that easy.
LMBTG
Sep 2, 2015 07:01 PM
rotor_veux
Aug 31, 2015 07:49 PM
c0rpse
Aug 25, 2015 11:50 PM
