Drifting Discuss Drifting and drifting techniques here.
look who it is....
Old Dec 27, 2011 | 07:45 PM
driftfcbuckey's Avatar
RX7-Factory
look who it is....
http://lasvegas.craigslist.org/pts/2765929175.html
looks like dude is starting to surface after screwing everyone on those fuel rails...
Old Dec 27, 2011 | 07:54 PM
Digi7ech's Avatar
I break Diff mounts
Darren?
He's still got a Phoenix number.
Some one should ask him for a mailing address so they can send a money order.
Old Dec 28, 2011 | 02:36 AM
monkey1911's Avatar
He posted that **** in seattle too, http://seattle.craigslist.org/see/pts/2766083023.html
Old Dec 28, 2011 | 11:41 AM
magus2222's Avatar
On the fasttrack!
well, there is a dude in modesto that stole this design and is selling them, look at the 2nd gen developement thread
or hell, could be darren back to screw more people, idk
Lloyd
Old Dec 28, 2011 | 11:48 AM
RotaryEvolution's Avatar
Sharp Claws
yeah, i don't think that is Darren. i don't think Darren ever even finished more than a single diff mount. the pictures he always shows are of half done products.
i just think this person wants to avoid vendorship on the forums and i was contacted about selling them for him.
these mounts are steel and remachined where darrens were all welded. even in the picture in that thread that mount was just tack welded and wasn't even complete. i think even darren knows better than to try and come back and rip people off for the same product.
darren's:
brandon's:
brandon's look nice, only issue i have is whether the studs will be able to hold up on the subframe side, it appears they are welded to the plate on the inside only. i can imagine they may crack and break loose under the stress eventually. it is more compact and a cleaner design though. most of the time the mounts break because they are behind more than stock power and abuse levels so the mounts must actually perform better than the original in mounting and hold ability. the design should work but i would weld the whole gap, not just the stud side and also use locknuts on the through bolts for the pucks, simple threading will not hold the bolts in place indefinitely.
i was going to make something along those lines but i think if he polishes up those few things on the mounts then i won't have to put the time into development. no need for 2 people to compete in the same limited market.
i can pretty much guarantee Darren's aluminum mount would have bent and failed in much less time than even an OEM mount would have. the stress on the sandwich will bend the soft material in no time flat, ripping shortly after. it takes a lot more R+D than just making a shiney product that looks nice, the chinese already have that market cornered and i figured we still had higher standards than ripping off our own.. but darren's motives eventually came out anyways so getting them repaired would have never happened even if they did make it through the finishing stages.
in any case, i do not believe you need to pay vendor fees to make induvidual threads for the group buy forum. that will help those of you who just want to sell one offs without paying the $75+ per month for vendor fees.
note: i am not liable if this does wind up being him again. take your own risk when dealing with induviduals and even some smaller businesses, do your research and get references. i just found it wasn't worth the small amount of money i could possibly make on reselling them if they did wind up failing and i was stuck holding the ball on an untested product if he did disappear. the price at $150 is reasonable though, for a fully rebuildable mount, assuming it holds up.
Old Dec 28, 2011 | 12:21 PM
Sharp Claws
i am also assuming that these are steel, i have never touched one so i am only going off appearance and the fact that they are painted. if they are aluminum, you're on your own.
Old Dec 28, 2011 | 01:31 PM
Digi7ech's Avatar
I break Diff mounts
That's a local member that I have prohibited from selling on my forum because he is or at least was a friend of Darin/Darren how ever you spell it.
I suspect these are Darins and he's going through friends email accounts/names. He's done this before locally.
His username there is Ilovemys5
Old Dec 28, 2011 | 03:58 PM
Sharp Claws
oh well, i guess i will have to add it back on to my list of things to do again.
hopefully this guy doesn't scam anyone else.
Old Dec 29, 2011 | 01:39 AM
RX7-Factory
where are my fuel rails.....
Old Dec 29, 2011 | 02:07 AM
mannykiller's Avatar
Garage Hero
Yea... I'd like mine too...
Old Dec 29, 2011 | 02:29 PM
RXILVER7's Avatar
Grabbin My Wankel
Don't know either of these guys Darren or Brandon, never done business with them or even heard of them, but If you're selling an RX7 specific part, not on RX7club and you're not local but using local classifieds to sell it, I don't trust you.
roarinrotaryrx7
31
Jul 13, 2006 10:05 AM
fcdrifter13
24
Apr 25, 2006 06:55 PM
wb123
Apr 10, 2006 07:34 PM
OaklandTII
Mar 23, 2006 08:48 AM
