DLIDFIS & my tach
Old Jul 20, 2002 | 04:02 AM
Hyper4mance2k's Avatar
The Shadetree Project
Exclamation DLIDFIS & my tach
one more question if i put in a DLIDFIS will my tach still work??? or would i have to put my old autometer one from my old car?? if it will work where would i hook it up? will i need a tach adapter thinggy from MSD?? and yes i used the search
Old Jul 20, 2002 | 04:03 AM
abeomid's Avatar
you tach will still work since you are not changing the trailing ignition and tach works off trailing
Old Jul 20, 2002 | 02:21 PM
schwanks fer da ansaw
Old Jul 20, 2002 | 02:54 PM
MIKE-P-28's Avatar
Driven a turbo FB lately?
Dont the early models run off the leading? I beleive I learned that lesson on Jermey's 79 when we converted it to electronic
Old Jul 20, 2002 | 03:13 PM
mar3's Avatar
Administrator
So you pull the tach wire off of the leading clip and put in on the trailing clip...
Old Jul 20, 2002 | 03:37 PM
jeremy's Avatar
male stripper
mar3, did you wake up on the wrong side of the bed again?
Old Jul 20, 2002 | 03:38 PM
MIKE-P-28's Avatar
Well I guess the point is mte if your converting it to direct fire
Old Jul 20, 2002 | 03:50 PM
mar3's Avatar
Administrator
That and don't the MSD boxes have a spot on them labeled "tach"??
Old Jul 20, 2002 | 03:51 PM
abeomid's Avatar
well for DLIDFIS you have to convert the ignition to the later models anyways
Old Jul 20, 2002 | 04:36 PM
mar3's Avatar
Administrator
I've been forced to the Saturday shift again here at SBC.........................dill weed.................
Old Jul 20, 2002 | 04:40 PM
jeremy's Avatar
male stripper
mike-p quoter
Old Jul 20, 2002 | 05:28 PM
REVHED's Avatar
Hunting Skylines
It doesn't make any difference! I have DLIDFIS and I run my tach off the leading.
Old Jul 21, 2002 | 03:46 AM
Jeff20B's Avatar
Lapping = Fapping
I've tried my tach on Leading and Trailing but keep it on Trailing so I'll know if my Trailing ignitor or coil ever dies.
Old Jul 22, 2002 | 04:00 PM
mar3's Avatar
Administrator
If the trailing goes, it's just gonna run a little rough. Wouldn't it be more disastrous if the leading ignitor went and you didn't catch it in time? Or not?
Old Jul 22, 2002 | 04:40 PM
peejay's Avatar
Old [Sch|F]ool
'79 and '80 have the tach off of the leading coil because the trailing coil is shut off some of the time, in order to keep the thermal reactor fed with unburned HC's.
'81-later don't use thermal reactors, so Mazda switched the tach signal to the trailing coil.
Old Jul 22, 2002 | 04:53 PM
mar3's Avatar
Administrator
The anti-rice superstar has done it again, ladies and gentleman!! Switch it back, Jeff20B or suffer the consequences...
Old Jul 23, 2002 | 12:54 AM
Jeff20B's Avatar
Lapping = Fapping
Hey now, I'm also an anti-rice
Anyway, if one of the Leading ignitors ever died, it would feel like it's running on one rotor. Thus no need to hook the tach to the Leading side. Also, if a Leading ignitor dies and you happened to have kept your old coil to cap wire, you could run L and T through your cap just like stock and never be stranded. My article explains all this and more. Click my www button.
Thor 18
Sep 28, 2015 07:35 PM
Casual_John
Canadian Forum
Sep 26, 2015 01:47 PM
subeone
Sep 24, 2015 09:58 PM
befarrer
Sep 22, 2015 09:33 AM
