What sensor is this?
Old Oct 15, 2011 | 02:08 PM
Robftw's Avatar
What sensor is this? my cars CEL code keeps coming on
i unplug it when the car is running, and then plug it back in and shut the car off.
After that, i start the car again and my CEL goes away. I'm assuming its this sensor, my question is which sensor is it?
The car studders and surges when the light is on it bucks badly and won't rev over 2k rpm unless i slowly, (extremely slowly) press the pedal down
Old Oct 15, 2011 | 03:22 PM
dwb87's Avatar
This is my social media.
I cannot see it very well. Maybe someone else will know by the connector.
Off subject a bit... but you really ought to cover that (B) terminal on your alternator.
Old Oct 15, 2011 | 03:25 PM
PvillKnight7's Avatar
air temp
Old Oct 15, 2011 | 06:23 PM
Robftw's Avatar
Thanks, i'm gonna pull it out and clean it.
hopefully the sensor isnt bad
Old Oct 15, 2011 | 07:06 PM
satch's Avatar
Is this an S4? Of all the factory sensors, the Air Temp sensor is the cheapest engine sensor and it's not close.
Old Oct 15, 2011 | 07:25 PM
j9fd3s's Avatar
Community Builder
air temp sensor. have you checked to see what the code is?
Old Oct 15, 2011 | 07:41 PM
Robftw's Avatar
its an S5, and i haven't ran the codes yet. However all of my problems keep leading back to this sensor.
I'm going to clean it and see what happens before i go in for a diagnostic
Old Oct 15, 2011 | 07:58 PM
satch's Avatar
Look at the Engine and Emissions section of the S5 FSM and look at the pinout list for the ECU and compare the reading at the proper ECU pin and compare it to spec. This will tell you what you need to know.
killerrx710
Sep 28, 2015 09:13 AM
killerrx710
Sep 24, 2015 10:57 PM
rotor_veux
Sep 19, 2015 07:13 PM
