Why is it popping?
Old Oct 15, 2011 | 08:53 AM
hatemy7's Avatar
Rotary
Why is it popping?
Ok the car turns on now with no issues! But when you accelerate it it's popping, we checked timing and it's on point, we checked the spark plug wires , coils are working. Whatelse can it be
Old Oct 15, 2011 | 10:34 AM
Aaron Cake's Avatar
Engine, Not Motor
Usually that would indicate a lean mixture.
Some info on the car?
Old Oct 15, 2011 | 12:25 PM
hatemy7's Avatar
Rotary
It's a 87 with a 91 motor ( JDM) also just changed new injectors and new coils. Spark plug wires . Just got the motor running not too long ago..
Old Oct 15, 2011 | 12:26 PM
hatemy7's Avatar
Rotary
It feels like a electrical issue. Not sure where to look at now
Old Oct 15, 2011 | 04:52 PM
walken's Avatar
Registered Loser
TPS and vacuum leaks.
Old Oct 15, 2011 | 06:21 PM
hatemy7's Avatar
Rotary
Tps. Vaccum leaks?
Well it has an open down pipe but I've ha other turbo2's with open down pipes and no issues.
And when you do put it in gear it struggles really bad. I won't move good at all. Turns on fine, just doesn't move well at all. But I will post a vid in a few seconds .
Old Oct 15, 2011 | 07:01 PM
satch's Avatar
Does it struggle at all rpm's? Are you using the ECU which came w/the engine? Have you pulled for error codes?
Old Oct 15, 2011 | 07:08 PM
hatemy7's Avatar
Rotary
no im using the ecu that came with the car. The car is an 87 turboII. motor is a 91, but I changed the oil metering pump from electronical to mechanical.
it seems to struggle just when its on gear but it pops even when its in neutral.
Old Oct 15, 2011 | 07:15 PM
satch's Avatar
So you are using S4 engine sensors? Is the throttle body S4 or S5?
Old Oct 15, 2011 | 07:17 PM
hatemy7's Avatar
Rotary
i believe its an S5
Old Oct 15, 2011 | 07:22 PM
satch's Avatar
What about the engine sensors? S4 or S5? If the throttle body is an S5 then are you using an S5 TPS? The S5 TPS has two pistons extending from the sensor while the S4 has but one.
Old Oct 15, 2011 | 07:30 PM
hatemy7's Avatar
Rotary
i think they are s5 as well. I am really not sure to be honest.
but i believe the tps is s5..
so do u think it can be the TPS?
Old Oct 15, 2011 | 07:34 PM
satch's Avatar
An S5 engine must be coupled w/the S5 ECU unless the engine sensors were converted over to S4. The S4 ECU will not properly run an S5 engine w/S5 sensors.
Old Oct 15, 2011 | 07:39 PM
hatemy7's Avatar
Rotary
really? ive had a similar swap before everything with s5 and just changed the oil metering pump and never gave me any trouble at all what so ever.
Old Oct 15, 2011 | 07:49 PM
hatemy7's Avatar
Rotary
here is the vid. not sure if you can hear it popping.
Old Oct 15, 2011 | 07:53 PM
satch's Avatar
Does "everything" include an S5 ECU? The S5 sensors provide different inputs than S4 sensors so the ECU needs to match the sensors used to make sense of the incoming information. The S5 sensors have a different number of wires than the S4 counterparts so they would not mate properly w/the S4 ECU. An S5 AFM has a different amount of wires compared to an S4, the Boost sensors are different in the wiring configuration and so on. I'll defer to others to give their opinion on the situation.
Old Oct 15, 2011 | 08:19 PM
hatemy7's Avatar
Rotary
oh ok did you see the video?
Old Oct 16, 2011 | 09:12 PM
RotaryEvolution's Avatar
Sharp Claws
try advancing the CAS timing 1 tooth and retry, advance the timing one tooth until the engine sounds more normal and see where the timing is at then.
Old Oct 16, 2011 | 09:53 PM
hatemy7's Avatar
Rotary
ok. I will try that tomorrow. Thanks boss.
Old Oct 17, 2011 | 01:34 PM
hatemy7's Avatar
Rotary
I'm about to check timing
Old Oct 17, 2011 | 05:29 PM
Bamato's Avatar
S5 T2
I'm with Satch. It doesn't sound like you have the right ECU/Sensor match-up. It does make a difference. I fail to see how an S4 ECU can run an S5 AFM, TPS, BAC, etc... Especially without making modifications that I'm sure you would have explained by now.
Unless I've missed something, you'll need to track down an S5 ECU and harness. And be sure it's a Turbo ECU of that's the case as well.
ls1swap
Jun 3, 2024 03:25 PM
renjiv2
57
Jan 25, 2024 03:34 AM
poop2003
Sep 21, 2015 10:28 PM
BUSTN
Sep 21, 2015 05:01 PM
