Cant go past 2000 rpms?
Old Jul 17, 2002 | 10:06 PM
Ok i cant, well when its realy hot out, go past 2000 rpms and then it starts jumping the car the guy i bought it from said that it was the thermo water valve or something i have a manual 86 gtx rx-7 and its got 3 tubes coming out of this water valve thing but in the big book of taking apart your rx-7 it is suppost to have only 2 is that what the deal is or can ne of you help at all thx.
Old Jul 17, 2002 | 10:20 PM
autocrash's Avatar
Now with more 1st Gen!
uhmm... if by "thermo water valve" you mean thermostat then I am confused... nvmind
better questions:
A) where is this "thermo water valve" located
B) what do you meant by "jumping"
Old Jul 17, 2002 | 10:32 PM
diabolical1's Avatar
yeah, i'm not sure i got what you meant, either ...
more info, please ...
Old Jul 18, 2002 | 06:34 AM
this thermo valve is located if your looking at the fron of engine it is located on the left corner in the back and it looks like a thick tube then has two stif tubes coming off for manual which is mine, but this guy i bought from had three coming off which is for an automatic so i dont get it, the jumping im talking about is you go up to 2000 then it stalls goes to 1500 then back up to 2000 realy quick kind like hittin the gas rapidly in 1st it starts like jumping the car foward and back, does that help at all and this only happens when its hotter that 90 with humidity, and it is called a water thermo valve i looked it up and theres a picture of a diagraphm however you spell that but theres one of an 89 with one in it but the 86 diagraphm doesnt have one so i guess ill just put a two hose and try it but there are three hoses and suppost to be 2 for manual two go to like an air in and out and the other goes to some stupid filter
Old Jul 18, 2002 | 07:00 AM
billzrx7's Avatar
id try yer cat, common problem is not being able to rev about 2-3k with a fouled up cat.
Old Jul 18, 2002 | 06:55 PM
autocrash's Avatar
Originally posted by aty6_ArEx-7
two stif tubes coming off for manual which is mine, but this guy i bought from had three coming off which is for an automatic so i dont get it stupid filter
We could probably assume from this that the car was originally an automatic transmission? or it may simply be a model difference... I doubt this is the cause of your problem.... what made you think it was?
This sounds like maybe 3800RPM hesitation (except earlier?? I would tend to believe that if it weren't for this:
I'm stumped.... maybe check your Catalytic convertor as was previously suggested....
BTW... that has gotta be THE most confusing post I have ever seen. If I might make a suggestion: Try and organise your information a little more clearly and hit enter occasionally (for example, you could have simply answered my 2 questions, with blank space in between (leave a line). It would make your posts much clearer to the reader and more people will answer as a result.
Old Jul 18, 2002 | 07:36 PM
1FastT2's Avatar
I would have to say the same thing, check that cat out.
Old Jul 18, 2002 | 07:41 PM
stinkfist's Avatar
Learn to swim.
? . , ! <-- Use these please.
Old Jul 18, 2002 | 07:57 PM
BoostedRotors's Avatar
I HATE sleepy eyes
My car used to do the same thing when it was hot, I adjusted the TPS and it stopped altogether.
Old Jul 18, 2002 | 10:05 PM
thx boostedrotors
Old Jul 18, 2002 | 10:06 PM
by the way whats the TPS? is it a throttle plate something?
Old Jul 18, 2002 | 10:09 PM
autocrash's Avatar
Throttle Position Sensor
alexdimen
20
Oct 23, 2015 01:50 PM
ChanBagz
Sep 17, 2015 03:36 PM
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
rx7shirley
Sep 2, 2015 02:11 PM
