rx8 engine rebuild
Old 10-10-11, 11:20 AM
serbRX7's Avatar
NY rx8 engine rebuild
rx8 engine complete bearing failure...this is the pic of front rotor baring that just fell out on its on... the other ones are just as bad
rotor housings look to be reusable
irons cam out excellent almost like new i was surprised
here is the e-shaft what do you guys think
front rotor where bearing just fell out on its on...looks to be damaged scared...not usable
and the rear rotor bearing still in place
bout rotor look good on the out side they didn't come in contact with the housings...bearing surface is damaged on the front rotor hoping to be able to use rear rotor
any way would like to get some opinions on this still new to rotary rebuilds hoping you guys can shed some light on this
Old 10-10-11, 12:18 PM
flaco's Avatar
whas it rebuilt before?? if so how long ago? and can you show a pic of the thrust bearings ???
Old 10-10-11, 12:37 PM
serbRX7's Avatar
yea trust bearings look to be in really good shape to... i can take some pic i will post them later tonight...
the rx8 water seals also looked like new...i was also thinking that the engine was rebuilt recently ...i do not know the history of the car i just got it for really cheap with blown engine...
Old 10-10-11, 01:11 PM
Sharp Claws
RotaryEvolution's Avatar
looks like a lack of lubrication issue, i would check into that before tossing the motor together and thinking all will be ok. bearings don't generally fail in these engines without a real cause.
the rotors are pretty beat up and the shaft is no longer usable so you will need a new shaft.
the housings all look good but i'd still recommend sending them to goopy to be resurfaced as i can see some ridges in the surfaces. they will also be able to help you with oversize bearings for the worn rotors.
Old 10-10-11, 02:51 PM
flaco's Avatar
prob ran with very low oil
Old 10-10-11, 03:41 PM
serbRX7's Avatar
Thy Guy I got it from don't know nothing about cars so he probably didn't know that rx8 drinks oil
Old 03-21-13, 06:10 PM
rexy91's Avatar
I hear the worse thing about buying a rx7 from peopke like that. Cross your fingers and wish for the best
Old 03-21-13, 06:36 PM
Sharp Claws
except the RX8 is very forgiving with the oil level light, the oil light comes on when the engine is approximately 1/2-3/4 quart low. the earlier engines wouldn't trip the light until the oil level was 3 quarts down and running on oil vapors.
so if he cooked the motor due to not adding oil he deserved to own a brick.
Old 03-22-13, 09:59 AM
serbRX7's Avatar
i didn't update this thread as i was going along...it was rx8 oil thermal pellet that failed
put the new engine together with solid oil thermal pallet...
had some problem along the way with rebuild...was my first rebuild..but everything got sorted out
ended up selling the car 1 year later as my soon was on the way...was relay sad after all that work...but i made some money on it and new owner is still happy with it
still got another spare rx8 engine ready for assembly debating on selling the parts still hopping to pick up another rx8 in need of help
bb6guy
Old School and Other Rotary
10-01-18 08:07 AM
Quick Reply: rx8 engine rebuild
