Fb oil pump question.
Old Jul 29, 2011 | 09:54 PM
MrTsims27's Avatar
TX Fb oil pump question.
I recently replaced my old nikki carb with a weber 45 Dcoe carb on my 84 Gsl and it did not come with the rod that adjusts the amount of oil that is pumped into the intake.We were told to just wire it all the open but it tends to smoke. I have been trying to fab one and was wondering if the oil pump still pumps oil when the lever is all the way down?
Old Jul 29, 2011 | 11:23 PM
rx71king's Avatar
the diabolical one
remove the metering pump and make a block off plate...i do not like pump engine oil into my rotarys...it leaves a lot of carbon deposits on face of the rotors..and one hot day a piece of carbon may come off the rotor and pop......pre mix is the best way for a happy engine . mix in a n/a 4oz for every five gallons...tc-w 2stroke oil......this is what i use....http://www.klotzlube.com/proddetail....5...:icon_tup:
Old Jul 29, 2011 | 11:49 PM
rx71king's Avatar
the diabolical one
i no some people do not like pre mix because it is more work and don't like adding oil every fillup....you can use one of theses...http://www.rotaryaviation.com/oil_in...p_adaptors.htm
Old Jul 30, 2011 | 02:09 PM
MrTsims27's Avatar
I think I will do that. So its 4oz per 5 gallons with 50:1 2cycle oil?
Old Jul 30, 2011 | 02:24 PM
PercentSevenC's Avatar
I need a new user title
Easier to calculate 1 oz. per gallon. Any TC-W3 rated oil should work.
Old Jul 30, 2011 | 03:32 PM
rx71king's Avatar
the diabolical one
it depends on what oil you decide to use...some 2stroke oils are thicker then others...if you use castrol go with 1oz pre gal...http://www.castrol.com/castrol/secti...tentId=7040924 .. por oil in the tank first before filling up...
Old Jul 30, 2011 | 08:21 PM
MrTsims27's Avatar
Cool. I was going to use this.
http://www.lucasoil.com/products/dis...02-CYCLE%20Oil
Would this work?
Old Jul 31, 2011 | 12:35 AM
rx71king's Avatar
the diabolical one
it will work..but it looks like this one will work better..http://www.lucasoil.com/products/dis...how&headTitle= - Lucas 2-Cycle Land & Sea Oil...it has a tc-w3 rating...
Snoopy FD
Dec 8, 2015 01:45 PM
rotor_veux
Aug 31, 2015 07:49 PM
