20b 15psi street port
Old Jul 19, 2011 | 01:07 PM
1988 gul's Avatar
Exclamation 20b 15psi street port
Im looking on getting a 20b and running stock twins with a street port. I need around 550bhp and streetable (i have a very loose definition of this haha)
Do I need bigger injectors to run at 550horse? and would the stock computer compensate for this? (I know you need the stock computer to run the twins so how are people doing this?) Would stock apex seals work? if not i found 2mm racing apex seals which should do fine.
Old Jul 19, 2011 | 01:35 PM
1988 gul's Avatar
(I am not worried about smog because this is going in to a pre-1975 vehicle.)
Old Jul 19, 2011 | 02:37 PM
Japan2LA's Avatar
Stock twins and a streetport wont make 550HP
Old Jul 19, 2011 | 02:48 PM
patman's Avatar
Resident Know-it-All
you are going to need an aftermarket ecu. (which you need anyway unless you want to run the stock auto trans)
on top of that, you will need a medium size turbo and at least the exhaust ports opened up.
Ian_D
Oct 14, 2015 12:31 PM
SCinfidel
Sep 8, 2015 05:36 PM
