17x10 +12 front wheels?
Old Jul 15, 2011 | 06:42 PM
point-blank's Avatar
Get Twenty Beeeeee
Is it possible to run 17x10 +12 on the front of my car?
I know I would definitley need some wide fenders, but would I run into any issues as far as clearance and drivability? The car does have/ will have coilovers and will be run probably 255/40 on all 4 corners
I checked that guide on fc3spro but it only goes up to 9" in the front
Thanks for any info!
Pics get bonus internets!
-Miles
Old Jul 15, 2011 | 06:58 PM
Hypertek's Avatar
Slowpoke
You will need spacers, but you wont know until you try the wheels on.. Then might need some small 4mm spacer to clear the coilover.
Old Jul 15, 2011 | 07:20 PM
Jross427's Avatar
Going Nowhere
I dont think u will need spacers if you have coilovers. U will need wide fenders
Old Jul 15, 2011 | 08:46 PM
Get Twenty Beeeeee
Even with that low of an offset?
Old Jul 15, 2011 | 08:57 PM
driftfcbuckey's Avatar
RX7-Factory
with a 10 you will rub coilovers in the front. my 9.5's at the same size with a +15 offset are litterally on the ride height collars. 3mm of clearance won't make up for the .5" of inner lip that will be on your coil.
you need spacers like he's saying. you'd need a 25mm bolt on, and even then there's no way in hell you'll be able to fit a 255 up front with the "small" wide fenders available. you'd need a 45mm+ front fender.
FC's like 9's up front. 9.5s even. 10s are over kill. you can run a 9.5 with a lower offset, or a bolt on spacer, and use a softer compound front tire if you're going for the time attack thing - which im assuming you are.
with a 10 up front you also will be rubbing all sorts of chassis/LCA up front.
just food for thought
Old Jul 15, 2011 | 09:17 PM
ben.farnath's Avatar
you would probably end up stretching on a smaller tire to clear the fenders which defeats the purpose of the 10inch wide wheels. so driftfcbuckey is right you might as well go for a smaller wheel. 10s are pretty overkill for up front
Old Jul 15, 2011 | 10:47 PM
Jross427's Avatar
Going Nowhere
You do thw math, im fitting 18x9's +24 with no coilovers and only beating the upper part of the fender to make it not stick out, so i cant even say i rolled my fender. My math isnt great but 12mm is ~1in. So his rims would have .5in more clearance on the inside than my set
Old Jul 15, 2011 | 10:49 PM
Jross427's Avatar
Going Nowhere
No spacers on coilovers*
Old Jul 16, 2011 | 12:59 AM
MaczPayne's Avatar
Mac Attack
Even with 9's, a 255 will rub off most of the plastic trim under lock. The problem is magnified with wider wheels and lower offsets.
Old Jul 16, 2011 | 02:44 AM
Get Twenty Beeeeee
how about a 9 with a +15 offset? I can fit the same amount of tire on there
Old Jul 16, 2011 | 02:46 AM
Jross427's Avatar
Going Nowhere
Like i said earlier im runnin 9's +24 with a 235 tire, if its a +15 your gonna need a roll.
Old Jul 16, 2011 | 03:03 AM
Get Twenty Beeeeee
I am not too concerned about fenders at this point, as I will probably be purchasing a set of aftermarket wide ones, only being able to clear the frame and suspension components
Old Jul 16, 2011 | 12:48 PM
MaczPayne's Avatar
Mac Attack
You'll clear the suspension, but your tire may rub on the rubber fender liners under lock.
Old Jul 17, 2011 | 05:29 AM
TheAbsence's Avatar
s4 Pride
1 inch = 25.4 millimeters
Old Jul 17, 2011 | 05:33 AM
RX7-Factory
anyone talking about fender liners needs to sit on the bench while the big boys fit wheels...
Old Jul 18, 2011 | 05:09 AM
Jross427's Avatar
Going Nowhere
Thank you, so with a x10 +12 youll be right on the ride height collars
Old Jul 19, 2011 | 01:13 PM
Get Twenty Beeeeee
[QUOTE=driftfcbuckey;10708334]anyone talking about fender liners needs to sit on the bench while the big boys fit wheels...
What tire size and offset are you running? looks dope
Old Jul 19, 2011 | 02:27 PM
MaczPayne's Avatar
Mac Attack
Some guys like to keep their fender liners, wasn't sure if the OP wanted his.
Either way, I ripped mine out.
17x9+20(+17 -3mm thinner rotor hat) 17x9+17 Rear, rolled and flared on all corners
255/40/17 x4
Old Jul 21, 2011 | 11:46 AM
Chriz88DX's Avatar
^^^ nice job bet that thing attacks corners. I am kinda in the same boat tho I ordered the new xxr 527's in gold 17x9.75 +25 hoping they clear the fronts
BNR34RB26DETT
42
Feb 28, 2018 11:27 AM
fidelity101
13
Aug 31, 2015 07:47 PM
