Don't use water filled battery!
Old Jul 14, 2002 | 12:56 AM
GoRacer's Avatar
Speed Mach Go Go Go
Thumbs down Don't use water filled battery!
There is a reason Mazda had the battery enclosed! It can "NOT" handle the heat!!!
Mine is evporating acid on my intercooler.
That stuff is like the blob and keeps ccomming back.
If you have a SMIC, then you are better off with the stock ducting than using a Pettit or whatever. Make sure you also have the plastic batter cover to enclose it.
If you don't, get a gell filled battery (Baker, M2, N-Tech, Odyssy, etc.)
Best yet, relocate it to the cubby hole bins behind the seats.
Old Jul 14, 2002 | 01:20 AM
artowar2's Avatar
Yeah the heat can really kill a battery fast. But to add to what you've discovered, I believe that the g-forces a stock FD can pull make it prudent to go with a sealed Hawker-type battery (or something similar-- the types that are advertised as not outgassing, and that can be mounted in any position).
And if you're relocating the battery inside the passenger compartment, a suitable sealed box, with vent tubes is a good idea. Personally, I wouldn't put a standard battery inside, even with a sealed and vented box. I've had standard batteries explode before, and it ain't something you want to be around (makes a nasty mess too...)
Old Jul 14, 2002 | 02:23 AM
GoRacer's Avatar
Speed Mach Go Go Go
Sealed box?
I know you have to do a sealed box when relocating to the rear to be track race legal but does it matter if it's a gel filled/sealed type battery allready? ...you still ned a sealed box or vent tube with a gel type battery?
Old Jul 14, 2002 | 03:40 AM
artowar2's Avatar
Just seems like a good idea to me. You're putting a heavy *brick* inside the car with nasty stuff inside. Thus, I believe it's a good idea to get a sturdy box as an enclosure. I would like to believe the sealed batteries don't outgas, but I would rather play it safe and vent the box. Last time I looked, Summit had a nice aluminum battery box with a gasket-sealed lid. You could drill the sides or top to put in your cables and vent tubes.
Old Jul 15, 2002 | 11:05 PM
GoRacer's Avatar
Speed Mach Go Go Go
Arrow More info
I tried a Baker Precision gel battery. The size was great, would habe worked with the stock box hold down, but the posts were on the wrong side of the battery and they were flat with a hole in them. ...not only do you have to change the ends, it doesn't reach. That's too bad, that was a nice battery (Even had plenty of CCA's).
So, I went with the tiny Odessy (motorcycle) 680MJ battery (MJ = metal jacket). The battery is about 1&1/2" shorter and I McGyver'd the hold down with a drafting plastic eraser (not duct tape) "lol". (But I will be ordering the kit from N-Tech.)
--> To clean up the acid, use baking soda!
* Make sure to do this, or else it keeps comming back like the blob!
If you are using a maintenance (water filled) battery, please purchase the shield below if you can "not" replace it with a gelled type.
http://www.thermotec.com/tt/battery.html
I also looked at the 1/2 sized Optima battery's but all Optima batteries are too tall for the hold down.
Old Aug 31, 2002 | 06:31 PM
GoRacer's Avatar
Speed Mach Go Go Go
I bumped this up because of the thread below...
https://www.rx7club.com/forum/showth...hreadid=110749
Old Aug 31, 2002 | 07:01 PM
RICKRX7's Avatar
Re: More info
[QUOTE]Originally posted by GoRacer
[B]I tried a Baker Precision gel battery. The size was
I put this wrap around and under my battery. Works good.
Old Aug 31, 2002 | 08:26 PM
GoRacer's Avatar
Speed Mach Go Go Go
Cool Here I come to save the day
Right on, I saved one battery and one engine bay.
Old Nov 5, 2002 | 06:57 PM
GoRacer's Avatar
Speed Mach Go Go Go
quote
There were also a few cars that had their batteries explode, a result of the intense underhood heat, and almost certainly directly attributable to the pre-catalytic converter, but this was apparently not common enough to warrant a recall, or sufficiently troubling to cause Mazda to rethink the inclusion of the pre-cat.
http://www.rotarypowered.com/3rdgenfaq.html
(Edited) Quote by: "Jimlab"
Old Nov 6, 2002 | 03:37 AM
Stevey629's Avatar
Rotor Shaped Blood Cells
does an optima batt. need a sealing box? will it still need the plastic heat shield if its in the engine bay?
Old Nov 6, 2002 | 12:04 PM
spurvo's Avatar
don't race, don't need to
Here's some fun. Previous owner didn't take maintenence to be THAAAAT important... battery was all corroded when I got it. Stupid me, I used the permatec spray foamy stuff to neutralize the acid that had collected all over the body near the battery. Some of the foamed battery acid and cleaner dripped onto the lower stock radiator tank. Now it looks like the floor plates in the various Alien movies... melted the plastic. Not all the way through, but enough for a VERY LOUD WTF on a Saturday morning the following week upon discovery.
Fluidyne arrives Thursday...
Old Nov 6, 2002 | 01:22 PM
JspecFD's Avatar
quote
I'll also add that when my Mazda battery exploded WITH the stock IC/ducting, there was also an M2 dp on the car.
streetlegal?
Mar 17, 2022 02:46 PM
FD7KiD
15
Feb 26, 2021 10:12 PM
FD7KiD
Aug 17, 2015 11:50 PM
