This makes me want to cry......
Old Nov 5, 2002 | 10:31 AM
djaaronp's Avatar
How could you let this happen......I just dont understand.........
http://cgi.ebay.com/ebaymotors/ws/eB...tem=1871640029
*snif*
Aaron
Old Nov 5, 2002 | 10:32 AM
M.Piedlourde's Avatar
Well, I'm sure the owner didn't INTEND for it to happen...
I saw that when I was looking on Ebay the other day. Looks like it got toasted pretty good.
Old Nov 5, 2002 | 10:55 AM
neoamd's Avatar
LS Powered
holy crap!!! poor rx7
im going to sit in the corner now..
Josh
Old Nov 5, 2002 | 11:05 AM
ttRx7racer's Avatar
I almost broke down right here
Old Nov 5, 2002 | 11:18 AM
7sweetie's Avatar
Pilots are hot!
****, that car is fucked, i wonder if its worth buying to fix up
Old Nov 5, 2002 | 11:30 AM
Arrow Could happen to you too!!
Sounds like the recall that was on a previous thread. It shook me enough to make a text copy and put it my archive so I don't forget about it.
Seems that there was a recall on the early 1993 Third Gens that when you drove your car too hard, didn't cool it off, the coolant can boil over and pool on the lower intake. Dripping on the exhaust manifolds of the turbos it ignites and catches the car on fire.
Recall only put an alarm and light on the filler neck to tell you that coolant is missing in the engine. The expected culpret was the turbo exhaust manifolds but it seems that it was cheaper to put the alarm on rather then replace the turbo manifolds which were redesigned for the later models. Redesign was attributed to easier maintenance.
So if that coolant gets hot and that alarm goes off, stop and check it out!! That or put a single on!
Old Nov 5, 2002 | 01:00 PM
spurvo's Avatar
don't race, don't need to
Another reason the stock gauge is CRAP. Get a gauge, or do the linearization mod. I command you. Now go forth...
Whatever
Old Nov 5, 2002 | 01:04 PM
teamstealth's Avatar
Ozone Depleter
thats terrible......how could you disregard your car like that??
Old Nov 5, 2002 | 01:30 PM
cabaynes's Avatar
Old and grumpy
like someone stated before, i dont think the owner intended for that to happen... if you car caught on fire you would probably run away screaming, looks like the guy saved it before too much damage happened... could have fried the entire car.
Old Nov 5, 2002 | 01:47 PM
DK's Avatar
DK
40k worth of fail
Note to self: Carry an extra fire extinguisher.
Old Nov 5, 2002 | 01:51 PM
neofreak's Avatar
accept no imitations™
At least its a red/tan 93.
Old Nov 5, 2002 | 02:08 PM
rfreeman27's Avatar
At lest?
Old Nov 5, 2002 | 02:22 PM
jimlab's Avatar
Super Snuggles
Re: Could happen to you too!!
I think you're confusing the fuel recall with the coolant recall...
Recall #1 - Coolant Recall
The coolant recall involved the replacement of some cooling system parts with stronger/more heat resistant materials and lowering the pressure of the cooling system from 1.3 bar to .9 bar. The parts replaced were the water pump seal, the water level sensor, the upper radiator hose, the filler cap, the filler cap body, the thermostat gasket, the water hose leading to the throttle body, and the water hose leading to the coolant separator tank.
Recall #2 - Fuel Recall
The fuel line recall involved replacing the fuel lines under the intake manifold with lines made from a more heat resistant material, and adding a fan control unit that runs the cooling fans if the coolant gets too hot, even if the car is turned off.
Recall #3 - Brake Recall
The brake recall involves the replacement of a vacuum check valve and hose leading to the brake booster. The original unit may stick when oily and cold, preventing power assist under braking.
The fuel recall is probably the one you were thinking of, which involved leaking and pooling of fuel on the lower intake manifold, which could catch fire if it came into contact with the exhaust/turbos.
There were also a few cars that had their batteries explode, a result of the intense underhood heat, and almost certainly directly attributable to the pre-catalytic converter, but this was apparently not common enough to warrant a recall, or sufficiently troubling to cause Mazda to rethink the inclusion of the pre-cat.
Apparently you can call Mazda Customer Service at at (800) 222-5500 with your vehicle's VIN, and they can tell you if all of the recalls pertaining to your model have been resolved. I'm not sure if that number is current, I grabbed it from the 3rd generation FAQ, which is where the recall descriptions came from also.
http://www.rotarypowered.com/3rdgenfaq.html
Old Nov 5, 2002 | 03:37 PM
Thanks, Jim. As always, good shiznit .
Old Nov 5, 2002 | 03:42 PM
7sweetie's Avatar
Pilots are hot!
jim is so smart
Old Nov 5, 2002 | 03:55 PM
ricola555's Avatar
My 93 had all recalls performed, and the engine still caught on fire. The FD is a pyro...I think it was Drew Barrymores car in Firestarter
Old Nov 5, 2002 | 06:23 PM
I had smoke coming from under my hood after an oil change. Turns out oil was dripping from the cross over tube coupler down to the exhaust. I saw flames. That + leaking fuel = boom!
GoRacer's Avatar
Speed Mach Go Go Go
I mentioned the battery before, but not everyone beleived me ...get a battery wrap or gel battery!
I new about the pre-cat but was stupid and procrastinated the down pipe and now i'm paying the price.
On the bright side, you can get a mountable small car fire estinguisher from Orchid hardware for only $12. I bought one, since my turbos are now leaking.
Old Nov 5, 2002 | 07:26 PM
fdslave_g's Avatar
A capital FD barbie
Man! poor car...poor owner too
Really wonder what the owner felt when his car catch fire Hope that's not gonna happen to any of us people
Old Nov 5, 2002 | 11:59 PM
rx4ur7's Avatar
nice hood!!
MazdaspeedR1
The Bad & Fugly Businesses
27
May 22, 2018 05:58 PM
jsesq
27
Sep 25, 2015 11:10 AM
ray green
1st Gen General Discussion
Sep 2, 2015 06:35 AM
