Premix
Old Jun 7, 2011 | 08:36 AM
Andoru's Avatar
Premix
Hello,
Wondering what a good amount of premix is to run in my fuel.
Removed the stock oiling system on my race car.
What is everyone running? I'm assuming at a certain point it will start messing up my octance level.
Andrew.
Old Jun 7, 2011 | 01:41 PM
rx761's Avatar
I run regular 87 octane, and use 4 oz of 2 cycle oil for every 5 gallons of gas.
Old Jun 7, 2011 | 05:04 PM
SCCAITS's Avatar
SCCAEP
1oz per 1 gallon. Valvoline 2 cycle multi-purpose. No OMP.
Old Jun 7, 2011 | 06:03 PM
TrentO's Avatar
I run 100:1 (250 ml for 25 L). I have a handy 250 ml container left over from some additive which I fill and upend into a 25L fuel jug before filling. Between blending 50%50% C16 and 94 octane premium and the oil I feel like a mixoligist.
-Trent
Old Jun 8, 2011 | 08:28 AM
nofords's Avatar
Mr. September FB 2011
I'm with Trent.
100:1 with 94 octane
No OMP.
Old Jun 8, 2011 | 09:01 AM
sleeper7's Avatar
13 oz. per 5 gal of race gas.
http://www.lucasoil.com/products/dis...02-CYCLE%20Oil
Old Jun 8, 2011 | 09:49 AM
Andoru's Avatar
Perfect, thanks gents.
I mixed in about 100:1 with my 94 (good guess!), car smokes a little on idle wasn't sure if I had too much.
Thanks,
Andrew.
Old Jun 8, 2011 | 03:29 PM
RockLobster's Avatar
Let's get silly...
128:1
1oz per gallon...
Old Jun 10, 2011 | 06:15 AM
peejay's Avatar
Old [Sch|F]ool
I've found performance increases all the way up to about 1:70 (roughly 2oz/gallon), haven't tested any richer than that.
Even this amount should not cause smoking at idle. But, the way I see it, if power keeps going up, that must mean that internal friction is going down, and if internal friction is going down, that must be better for the engine.
I wouldn't run it that rich on the street, mind you. I run about 1:200 on the street.
Old Jun 10, 2011 | 01:56 PM
BLUE TII's Avatar
Rotary Motoring
When I was using RA super seals I ran 50:1 premix (quart on fill up) and the stock OMP set to go to max on a turbo car.
Seals still wore the holy hell out of the housings, but I had minimal smoking with the right premix (I like Mercury Quicksilver) and man the engine so clean on the inside, very light carbon in exhaust ports only @25k miles.
Cause of death- egt probe broke/melted off and pinched cornerseal.
Only time I had an issue with too much premix is when I put in a quart, drove to the gas station and put in 10+gallons of gas. The short drive of 20:1 premix fouled the trailing plugs and I had to rotate them into lead position. BTW, not much smoke.
Old Jun 14, 2011 | 07:09 PM
silverfdturbo6port's Avatar
500+hp club
that because you used SUPER SEALS classics dont.
I run 1:1
Old Jun 17, 2011 | 03:43 AM
Bakemono7's Avatar
1:1??? so you put gallons of 2 stroke oil in?
Old Jun 17, 2011 | 12:20 PM
500+hp club
128:1 typo
20B Forum
21
Mar 22, 2022 01:00 PM
Andrew7dg
Aug 6, 2017 01:41 PM
Frox
Oct 22, 2015 04:54 PM
JP's 93 fd
Sep 16, 2015 01:12 PM
