Power FC INJ vs Base tab
Old May 29, 2011 | 11:55 AM
rx74evers's Avatar
INJ vs Base tab
Hey guys is the INJ tab same as the Base map tab? The reason is when I richen the cells in the INJ map and look at the Base map the cells in the Base map doesnt change. Why? I know when I richen the some lean cells in the INJ map it does work and changes accordingly cause I can verify it through my Wideband datalogit and the LOG works.
Old May 29, 2011 | 12:04 PM
rx74evers's Avatar
oh and also I am currently using BDC stock basemap since they seem to have a good Rep and pretty confident and verified with the Wideband and Knock is also pretty low... I have basic bolt ons with test pipe so im slowing riching some cells accordingly. Any opinions on their IGN maps? I have not check the boost cells yet do to weather conditions.
Old May 30, 2011 | 07:04 AM
Banzai-Racing's Avatar
Rotary Specialists
INJ is a correction map, to make the changes permanent to the BASE you need to press "recalc base" under "Tools".
Old May 30, 2011 | 10:41 AM
tom94RX-7's Avatar
in the base map tab you can select base x inj from the drop down menu to see how much the base map changes from changing the inj correction map
Old Jun 1, 2011 | 09:18 PM
rx74evers's Avatar
Thank you.
Old Jun 1, 2011 | 09:57 PM
cewrx7r1's Avatar
Eye In The Sky
There is one danger in doing a Re-Calc.
If you have a functioning Air Pump, O2 Sensor, and use O2 FB like stock;
it will ruin idle fuel control.
Save the INJ settings for N1-N6 for P1-P6, set them to 1.00, recalc, then replace the values back.
Actually with O2 FB turned off, you can actually tune idle better.
zyph3r
Canadian Forum
Sep 16, 2018 07:14 PM
RX200013B
Haltech Forum
Oct 12, 2015 09:45 PM
93FD510
Oct 1, 2015 02:00 PM
Smokeyfb33
Old School and Other Rotary
Oct 1, 2015 12:10 PM
Jmpabon93
Sep 30, 2015 04:57 PM
