Naturally Aspirated Performance Forum Discussion of naturally-aspirated rotary performance. No Power Adders, only pure rotary power! From the "12A" to the "RENESIS" and beyond.
what exhaust size r u using.
Old Apr 1, 2011 | 06:50 PM
jorx7's Avatar
Question what exhaust size r u using.
i have the full racing beat exhaust system. which i love but want to go to a single again. its a pain when i have to do work to remove both pipes. im thinking of using 1 of the rev tii exhaust mufflers from racing beat,which is a 2.375 inch dia. then just having my welder make the conecting pipe from the silencer to the muffler. cause i want to still keep the exhaust noise lower than a apexi style muffler. im going to be running a full bridge with exhaust port and huge street port. motor will be done in a couple weeks. thanks john
Old Apr 1, 2011 | 06:57 PM
jorx7's Avatar
well found out have to do a full 3inch if i go single. just got to figure out how to make the power with out waking up nyc in the process
Old Apr 1, 2011 | 07:12 PM
fidelity101's Avatar
Rallye RX7
yeah not gonna happen...
Old Apr 1, 2011 | 08:06 PM
jorx7's Avatar
yeah was wondering if did a loop with 2 silencers then to the muffler. might work
Old Apr 3, 2011 | 09:42 AM
rotormind's Avatar
I have the rb streetable exhaust without the mufflers, I am planning on collecting it at the back with a 3" exhaust and muffler. It comes with 2 precilencers so with the right muffler, hopefully it wont be too loud. I'll let you know when it's done.
Old Apr 3, 2011 | 04:26 PM
jorx7's Avatar
do you have a full bridge port? ill have my motor in 2 weeks. will bolt up what i have. but going to call racing beat see if i need to take out their silencer which has a gap in it to make back pressure. cause all ive heard is brige ports dont like backpressure. so replacing their rb silencer with a regular silencer will prob make my hp numbers good.
Old Apr 28, 2011 | 08:43 AM
ArmyOfOne's Avatar
Bridge Port Freak
I am making pretty good power using one of their TII pre-silencers. All I did was remove that little back pressure tube from the exhaust stream and weld a cap on that side. The trick to a comfortable and quiet exhaust is more a function of tubing wall thickness more so than what muffler you use. So the thicker the better.
Old Apr 28, 2011 | 10:38 PM
Rallye RX7
That's what she said...
Old Apr 29, 2011 | 11:25 AM
ArmyOfOne's Avatar
Bridge Port Freak
Lol.
FD7KiD
15
Feb 26, 2021 10:12 PM
Frisky Arab
13
Aug 18, 2015 05:30 PM
FD7KiD
Aug 17, 2015 11:50 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
