Electromotive TEC Discussion of all Electromotive TEC systems.
Electromotive Tec 3 Latest Firmware upgrade = No Injector Fire
Old Mar 23, 2011 | 10:40 PM
Quadragin's Avatar
On my sand car, I upgraded my Tec 3 to the latest Firmware, i did not have the old .BIN file so I started from scratch using the wizard. the car would not start.
A local guy came out to look tune the car he could not get it running ether, what he found was that the injectors are not firing.
I have power to them, we cam manually pull them to ground, they fire.
Needless to say we are at a loss.
Prior to the upgrade the car ran fine.
Any help would be great. Tried to call Electromotive = No Answer
Old Mar 28, 2011 | 07:47 PM
85turbo12a's Avatar
nerd
EMI can be difficult to contact occasionally, but they are very helpfull.
try here also, lots of helpfull ppl and the EMI guys moderate it http://electromotivetec.freeforums.org/index.php
as for your issue....who knows, EFI does weird **** sometimes...i have had my share...but youll find the culprit eventually.
Old Mar 28, 2011 | 07:56 PM
R-R-Rx7's Avatar
Rotor or no motor
i never had a problem to get in touch with electromotive. are you sure you are dialing the right number?
Old Mar 28, 2011 | 10:47 PM
Quadragin's Avatar
I got ahold of them Uwe was his name. I sent him my BIN, he and an engineer could not figure out why my injectors are not firing. Im sending them my ECU.
BTW I can jump them to ground and the engine fires and run a little,
jsesq
27
Sep 25, 2015 11:10 AM
SCinfidel
Sep 8, 2015 05:36 PM
tonka_1956
Sep 2, 2015 05:55 PM
