Can't budge short oil cooler line (male) : Help!
Old Jul 7, 2002 | 03:29 PM
WKeene's Avatar
Trying to take off the short oil cooler line from the engine(86na). It has a male threaded end going into the engine. There seems to be an outer nut in the hose to hold it in place while manipulating the smaller hex fitting. I can't get the smaller hex to budge with respect to the larger OD hex. The male end is loose with respect to the engine.
The small fitting isn't press fit into the larger one is it?
Any suggestions?
Thanks
Old Jul 7, 2002 | 04:12 PM
WKeene's Avatar
bump...
Should I be able to loosen this bolt (male) without rotating the hose?
Suggestions please...
Old Jul 7, 2002 | 04:49 PM
there are two nuts.. I loosten the outer nut first.. Then the inner nut second.. works for me..
I never do anything by the book .. But has worked for me..
Old Jul 7, 2002 | 04:55 PM
WKeene's Avatar
Right...2 nuts. But that's just it....I can't budge that outer nut....its really on there.
Is this common for the outer nut to be stuck?
Going to replace it with steel braded hose from Corksport....maybe at this point it doesn't matter if I just cut the hose.
Old Jul 7, 2002 | 05:06 PM
HAILERS's Avatar
HAILERS
There's a union screwed into the housing. Then the hose nut screws on to that union. You need to break the hose nut from the union. If you can.
If you have the new hose on the way, I guess you could cut the thing off. Its a shame, because you could have used the old one as a spare.
Old Jul 7, 2002 | 05:09 PM
Roy James's Avatar
My cars louder than yours
those things are a bitch, this is what i had to do one time but i dont recomend it. I put some big vise grips on it and beat the *** out of it with a hammer until it moved, then just used a wrench the rest of the way. Good luck.
Old Jul 7, 2002 | 05:37 PM
rgordon1979's Avatar
LS what?
same problem
I just replaced my oil cooler lines this weekend and had the same problem. I ended up cutting the metal part of the hose, unscrewing both from the engine together, and then separating them. It would have been nice to have a spare, but mine were in pretty bad shape. Good luck..
Old Jul 8, 2002 | 08:59 AM
Aaron Cake's Avatar
Engine, Not Motor
There's an easy way to do it. You may need to remove the belly pan for this. Get an adjustable wrench, and set it for the size of the inner nut. Now set a jackstand on the ground below the wrench. Wedge a piece of 2x4 between the jackstand and the wrench so it's solid. Now, with a pair of vice grips (or even better, the properly sized wrench) loosen the outer nut. Works everytime.
Do NOT put much stress on the hose, it will bend.
FD7KiD
15
Feb 26, 2021 10:12 PM
FD7KiD
Aug 17, 2015 11:50 PM
