Naturally Aspirated Performance Forum Discussion of naturally-aspirated rotary performance. No Power Adders, only pure rotary power! From the "12A" to the "RENESIS" and beyond.
Intake Manifold's Semi PP and a few question's
Old Jan 15, 2011 | 08:41 PM
S1sevenNZ's Avatar
1) Got my self a 13b 6port from a S4, Wanting to no if a S5 N/A UIM would flow enough with a custom LIM and a semi pp ??
Anyone got any thought's on this ..... yes, no, maybe, or go IDA or holley with custom manifold
2) Are the c.a.s in 13bt and 13b n/a the same ??
3) How do you tell the diference between n/a and turbo rotor's, The depth of the rotor bath ?? anything else ?
Cheers.
Old Jan 15, 2011 | 09:34 PM
ultimatejay's Avatar
I don't know the answer to #1 but I think the Cas are the same. The N/A 9.7 rotors have a 26cc combustion pocket. The turbo one's have more. I think around 36cc's.
Old Jan 15, 2011 | 11:43 PM
K-Tune's Avatar
FD Daily
The cas are indeed the same, for turbo rotors i look for a T that's cast in near the bearing.
Old Jan 16, 2011 | 01:03 AM
diabolical1's Avatar
from what i've seen regarding question 1, the engine will run, but you probably will not be allowed to use the engine anywhere near its full potential.
Old Jan 16, 2011 | 04:10 AM
S1sevenNZ's Avatar
Sweet cheers for 2 and 3, For 1, Yeah your probably right diabolical1, The s5 intake is a 3 piece and was hoping if i could just use the top part for the throttle body and make the rest up it would be ok to flow what it would require.
Old Jan 16, 2011 | 05:59 PM
Originally Posted by S1sevenNZ
... The s5 intake is a 3 piece and was hoping if i could just use the top part for the throttle body and make the rest up it would be ok to flow what it would require.
well, considering my semi-peripheral project has been shelfed now for over a year, this is purely conjecture on my part, but here goes. while i don't think any part of the stock manifold is ideal for a semi-peripheral, i would tend to think the throttle body and plenum (or dynamic chamber or whatever) would be your main restrictions - particularly upstairs. i think you'll have a hard time feeding all 8 ports without either more plenum volume, more throttle area or both.
Old Jan 17, 2011 | 12:19 AM
GtoRx7.'s Avatar
Cheers.
In a few weeks I should have pics of stock intake manifolds modified with semi p-ports. Our system places additional throttle bodies on the side of the engine. This will make for a powerful system. Lower intake with throttle bodies will be around $500 or so. PM me, or post on here if you have other questions
Old Jan 17, 2011 | 01:17 AM
S1sevenNZ's Avatar
Cheers diabolical1, Done some more reading, And look's like stock manifold's are pretty much no good for anything bigger than a SP, But would be interested in seeing pic's of GtoRx7's modified intake's for semi PP's .......
Also : http://www.rotaryonline.com.au/produ...ld-semi-p-port
But only avalible for FD and Cosmo block's.
Old Jan 18, 2011 | 04:02 AM
S1sevenNZ's Avatar
Are there differences between a S4 and S5 6port iron's ?
Just noticed my motor has got S5 TII housing's, flywheel and front cover and was told it was a s4 n/a block .........
Old Jan 18, 2011 | 11:55 AM
TheDriver216's Avatar
Get the shovel and boots!
pro-jay has 6 port manifolds as well as the other engine setups... http://www.pro-jay.com/SEMI-PERIPHER...NIFOLD_c15.htm
Old Jan 19, 2011 | 02:45 AM
S1sevenNZ's Avatar
Just striping motor now, Near the bearing on rear rotor there are 3 letter casting's, A, C, S, Any of these mean anything ??
Old Jan 19, 2011 | 04:59 AM
not sure why you have an A and a C on the same rotor, but those letters usually refer to the rotor's weight for balancing purposes. do you have photos?
Old Jan 19, 2011 | 12:02 PM
S1sevenNZ's Avatar
Yep will get some photo's tonight, The front rotor has got A,B,7 near the bearing.
Old Jan 19, 2011 | 01:10 PM
it's possible some of the characters you're seeing are kanji. based on the S4 rotors i have right here, my guesses are the A's and the 7. however, the photos should help prove or disprove that.
Old Jan 20, 2011 | 03:20 AM
S1sevenNZ's Avatar
Here are some pic's, Just measured up the front counterweight and from what i found on aus rotary it's a s4 weight, So the rotor's prob are too .....
Just need to find out now if they are n/a or not ??
Old Jan 20, 2011 | 06:32 PM
rotatrix's Avatar
yep deffinitly s4,you can tell as the s5 onwards rotors had machining marks though the tub on the face of the rotor,duno wether there n/a or turbo,you would need to measure them,the look like turbo ,but its always hard to tell in photos!
Old Jan 21, 2011 | 04:04 PM
S1sevenNZ's Avatar
Sweet cheers man.
Old Jan 21, 2011 | 11:51 PM
S1sevenNZ's Avatar
Found info on the combustion pocket depth :
s4 t2...1/2" 8.5 comp.
s4 NA 3/8" 9.4 comp.
s5 NA 11/32" 9.7 comp.
s5 t2 ??(less than 1/2" but more than 3/8") 9.0 comp
Look's like my 6port block has got 13bt rotor's, Oh well semi pp project on hold for now ....
Old Jan 22, 2011 | 02:48 PM
rotatrix's Avatar
thats no good man!how are you going to do your pports?
Old Jan 22, 2011 | 10:17 PM
S1sevenNZ's Avatar
Yeah im not happy a, I got a mate that's going to do the porting
Old Jan 23, 2011 | 12:36 PM
rotatrix's Avatar
sweet,ive got a s4 race car that ive been looking at building a semi-pp for but im still trying to work out the best way of doing it,dnt really want to waste a set of good housings trying!
Old Jan 23, 2011 | 05:32 PM
S1sevenNZ's Avatar
No that would really suck if ya did that ha, My mate has never done semi p-port's before but has done plenty of standard porting, He's got the correct gear to do it and plenty of old housing's to practice on first, but yeah see how it goes, What intake and exhaust set up were you gona run ??
Old Jan 23, 2011 | 11:40 PM
i'm not sure if you have seen this, but i think it is a pretty useful thread to help with reliability of the ports themselves.
Peripheral Port Sleeve Help? by Kenku.
Old Jan 24, 2011 | 01:50 AM
S1sevenNZ's Avatar
Thank you, Will have a read of that, Any info on porting of pp's and semi pp's is always good, And also if there's any link's or pic's for custom manifold's etc would be helpful too, Cheers. Exhaust will probably be 1.7/8'' twin pipe's to rear collecting into 2.5'' over diff and out, Just gota sort out my new block or just use the TII block that's already running in car now and get some high comp rotor's, mmmm not sure yet.
Old Jan 24, 2011 | 12:31 PM
rotatrix's Avatar
yep ive read that to,its just getting access to the right machining is gunna be the trick!im currently running 1 7/8 primarys to the rear and merging at the rear mufler and running a 48ida(the current engine is a 13b bridgeport) but i need to re-work the exaust slightly and ive got a microtech to run injection later on,if i do end up building the semi pp id like to run it on the ida to start (real easy to setup and run)im interested in what can be achived with a semi pp!!
