Other Engine Conversions - non V-8 Discussion of non-rotary engines, exc V-8's, in a car originally powered by a Rotary Engine.
EVERYONE!!!- 1or2 JZ swap??
Old Jan 10, 2011 | 05:12 AM
scotty R's Avatar
ON EVERYONE!!!- 1or2 JZ swap??
hey all
just wondering if anyone has done a 1 or 2 JZ engine swap on there FD , and if so any problems or hidden little tricks to it?? please explain.
im in the process of buying another FD but am really considering swapping the rotary out for a piston
thanks for the feed back and take care
Old Jan 10, 2011 | 05:35 AM
Ceylon's Avatar
Non Runner
Arrow
https://www.rx7club.com/other-engine-conversions-non-v-8-118/anyone-considering-2jz-1jz-swap-please-read-917008/
https://www.rx7club.com/other-engine-conversions-non-v-8-118/my-2jz-rx7-912137/
May be of use to you.
Old Jan 10, 2011 | 08:32 AM
scotty R's Avatar
thanks so much man! awesome thread to go on
Old Jan 10, 2011 | 09:55 PM
MK3Brent's Avatar
FD3S
I'm doing a 2J with the steering rack in the stock position.
If I could do it again, I'd move the engine back into the firewall probably.
Old Jan 10, 2011 | 09:58 PM
Supramonster's Avatar
2jz all the way... This should be one hell of a car when you get done with it. You against the ls swap? The only thing with those is there are just too many people already doing them.
Old Jan 10, 2011 | 11:09 PM
YoshiFD3S's Avatar
FD + 2JZGTE = WIN! **D
So I'm assuming you're going to run the Scoot Hood or something similar, to account for the clearance issues you're going to encounter.
Old Jan 10, 2011 | 11:19 PM
Black Magic's Avatar
2355lbs...
single rotor conversion is the new hyphy...
Old Jan 11, 2011 | 06:40 AM
scotty R's Avatar
ON
would it be that much of a difference moving the engine all the way back to the fire wall?? and did u guys have to relocate engine mounts or anything? and yes i do like the LS1 swap but everyone seems to be doing that one these days , plus i love the 2JZ
Old Jan 11, 2011 | 07:06 AM
Ya that is what I figured. 2jz is just different and you can make a whole lot of power. Interesting build though man.
Old Jan 11, 2011 | 11:46 AM
MK3Brent's Avatar
FD3S
With the height of the 2JZ, with .25" clearance to the rack unmoved is too tall for the stock hood AS WELL as after market hoods. (Minus the Tech2 sperm whale hood.)
The only way to get the Scoot hood to fit is to remove the vents.
I'll be making my own hood.
Moving the engine further back into the firewall allows for clearance at the crank pulley / oil pan to bring the height of the engine down w/o interfering with the rack in the stock location.
My experience with others and their bumpsteer correction kits were unsuccessful.
Old Jan 11, 2011 | 04:03 PM
mopar97's Avatar
yaa as far back as possible. as long as the tie rods are parallel with the control arms/ground you wont have bump steer. all the correction kits do is lower the tie rod mounting point to the steering knuckle
and yea **** the tech 2 hood...ruins the body lines.
Old Jan 11, 2011 | 04:38 PM
LETHAL RX7's Avatar
I lowered the rack in mine and in turn had to make spacers for where the tie rod ends go to the spindles..problem solved just as mopar97 said..
Old Jan 11, 2011 | 05:18 PM
MK3Brent's Avatar
FD3S
I initially moved the rack 2" lower, but then couldn't even fit my fist between the ground and it.
I got worried and then went to a tech2 subframe.
Stock suspension, wheels, and size tires.
Old Jan 11, 2011 | 05:26 PM
YoshiFD3S's Avatar
Really, it's just the valve cover that created clearance issues in my case, even with the steering rack lowered by 2" on my 2J setup.
I COULD fit a stock hood at this point, but instead my metal fabricator just modified my hood. See pics below:
BEFORE
AFTER:
He did a good job, I think.
I'd still like to go with a Scoot Hood though eventually, though.
Old Jan 11, 2011 | 05:35 PM
MK3Brent's Avatar
FD3S
That's basically how my hood is going to look.
I'm going to cut out a window, measure, and fill just like that.
Old Jan 12, 2011 | 08:21 AM
scotty R's Avatar
ON
gotcha!!
that fabricated hood looks really good! still has the stock looking effect to it just a lil bump to it but it goes with the car. how much did it run you to get done if you don't mind me asking?
and i def see now how much difference pushing the engine back to the fire wall!! and it seems everyone has there own different experiences with re-alining there ti rod/control arms?
Old Jan 12, 2011 | 08:33 AM
20b.
Old Jan 12, 2011 | 09:52 AM
MOBEONER's Avatar
It's finally reliable
The destruction of a rare sports car. It hurts..
Old Jan 12, 2011 | 11:12 AM
In fairness, I prefer to see a Supra motor in the bay instead of a Camaro motor. At least it's Japanese and sounds damn good
Old Jan 12, 2011 | 05:09 PM
MK3Brent's Avatar
FD3S
Not your jizz, not your bizz.
Old Jan 13, 2011 | 01:52 PM
got_hp's Avatar
from what i can find:
2jz weight = 594lbs
1jz weight = 478lbs
for comparison
LS1 weight = approx 430lbs
this is without the trans, so assuming you would use the same trans for either setup, the 1jz saves you over 100lbs off the front end, which is huge!
this is definitely something to take into account, since the 1j/2j center of weight will be much further forward in the car than the LSx or 13b, throwing off the balance.
personally i would go 1jz to minimize this affect. it also happens to be less expensive, and has better clearance. benefits of the 2jz would be more displacement, and more aftermarket parts, especially used stuff.
Old Jan 16, 2011 | 02:38 PM
scotty R's Avatar
ON
true say! and the 1JZ is roughly the same power as the 2JZ, that is a huge difference tho in weight between the two
Old Jan 16, 2011 | 06:34 PM
ProjectD's Avatar
I'm on a Boat!
Don't do it! you will ruin the handling! not to mention removing the rotary is like removing the soul. It won't be an rx7 anymore. If it was supposed to have pistons it would be a px7. That being said.....I vote 2J
Old Jan 16, 2011 | 07:54 PM
MK3Brent's Avatar
FD3S
You kidding?
Old Jan 17, 2011 | 06:46 AM
scotty R's Avatar
ON
lolol
PX7 it is then !!!!
Wehavetocook
Sep 23, 2015 11:04 PM
gtcd
Sep 17, 2015 01:15 PM
gabescanlon
Sep 15, 2015 06:57 AM
jakeishness
11
Sep 11, 2015 11:33 AM
