Front E-Shaft Bolt Washer?
Old Jan 9, 2011 | 05:19 PM
thewird's Avatar
Is there a washer on the front e-shaft bolt for 3rd gens? I thought I was missing it as its in the parts diagram so i ordered one. But now a local engine builder says 3rd gens don't have one so maybe I was never missing it? It's not listed in the service manual but it is in the parts diagram. So is it one of those optional things?
thewird
Old Jan 9, 2011 | 05:59 PM
No washer. O-ring on the rear of it. Lock-tite on threads and silicone on the rear mounting hub.
There is a rectangular-shaped piece that goes around the 19mm hex and two of the M6 bolts. Not required.
Old Jan 9, 2011 | 06:15 PM
Gorilla RE's Avatar
GorillaRaceEngineering.co
Only on OE main pully. It doesn't fit on the smaller after market ones
-J
Old Jan 9, 2011 | 06:18 PM
thewird's Avatar
Ah, so I wasted $3. I guess it wouldn't hurt to use the washer? Or just torque it as is? Yah, I got a new oring for it and was planning to do the same thing (loctite on the front and silicone on the back).
thewird
Old Jan 9, 2011 | 08:08 PM
twinsinside's Avatar
That's weird I was just looking at that today myself. Looks like the RE has a crush washer or something that goes on there but the REW doesn't.
Old Jan 10, 2011 | 08:26 AM
Gorilla RE's Avatar
thewird
It will be easier for an oil leak to occur if the washer is used. Just use the bolt, O-ring, loctite (not a lot, threads only) and sealant (on the bolt neck-head contact surface), then torque to 200ft,lb.
-J
FD7KiD
15
Feb 26, 2021 10:12 PM
astrum
24
Nov 15, 2017 08:44 AM
FD7KiD
Aug 17, 2015 11:50 PM
rx7jocke
Aug 15, 2015 03:36 PM
