Rich/Lean screw question..
Old Jul 3, 2002 | 02:06 PM
Rxmfn7's Avatar
Do a barrel roll!
I was thinking of trying to squeeze a little more power out of my car by slightly advancing the timing, and maybe leaning it out via the R/L screw. Before I did this I just wanted to know if it was possible to lean it too much via this screw, or if I should just crank it all the way lean? Is there really a noticable HP increase in doing this, or should I just leave it alone? Thanks.
Old Jul 3, 2002 | 02:07 PM
E6KT2's Avatar
That is the idle mixture screw. Don't mess with it.
Old Jul 3, 2002 | 02:12 PM
dre_2ooo's Avatar
You can adjust it all you want. It only effects idle .
Old Jul 3, 2002 | 02:32 PM
Rxmfn7's Avatar
Do a barrel roll!
Ahh..ok thanks. The only reason I asked is because I thought I remembered someone saying that you could lean out the fuel mixture via that screw. I got kinda excited OK though, I wont mess with it then
Old Jul 3, 2002 | 03:24 PM
Aaron Cake's Avatar
Engine, Not Motor
If you want to tune fuel, get the S-AFC. It does a great job.
Old Jul 3, 2002 | 03:29 PM
Rxmfn7's Avatar
Do a barrel roll!
Yea, but I dont think my mods list warrant the need for the S-AFC yet. I just thought I could do a little with the screw. Guess not.
Old Jul 3, 2002 | 03:33 PM
NZConvertible's Avatar
I'm a boost creep...
You don’t have to have any mods to fit an S-AFC. You said you wanted to squeeze a little bit more power out of you car, and that’s exactly what the S-AFC can do, by leaning out the very rich top end mixtures. This is best done on a dyno though.
Old Jul 3, 2002 | 06:59 PM
Angel Guard Racing Team's Avatar
My idle does not change at all when I move the screw!!! Initial set is jumped when doing so (Just in case)
Also it does not do any diference in my TPS in other words I can't tune the TPS. If I move the sensor itself it makes the light turn on but not by moving the screw.
Old Jul 3, 2002 | 07:07 PM
What the hell is wrong now???????
Andrew7dg
Aug 6, 2017 01:41 PM
Chiaszy
Sep 23, 2015 01:43 PM
