removing smog pump
Old Jul 2, 2002 | 10:07 PM
josh greene's Avatar
87 T2
Thumbs up removing smog pump
hey i dont have emitions were i live and was wondering about removing the smog pump off my 87 n/a. was wondering if it has any hp benifets or any at all also if theres any uneccesary emisstions part i could take off.
Old Jul 2, 2002 | 10:22 PM
NZConvertible's Avatar
I'm a boost creep...
Third time today...
Go here
Old Jul 3, 2002 | 02:25 AM
Jimmy325i's Avatar
No longer cares
NZ, Not to get into a little post competition with your ego or anything, but you just showed him how to not make his car run right.
You only need the smog pump if you have working 6 ports and want to keep them working. If you've wired them open or removed the sleaves then you can take it off without any problems.
You'll need an ACV block off plate as that won't be needed anymore either.
If you want to keep your 6 ports working, you'll need to come up with another method of providing the air pressure or some form of mechanical opperation of the solenoids.
My air pump is only connected to my 6 ports.
Old Jul 3, 2002 | 05:46 AM
The aux port system on an 87 is operated by exhaust backpressure. It's the 89-on engines that use the air pump.
I could come up with some witty comment about this, but I just can't be bothered...
Old Jul 3, 2002 | 05:58 AM
Roy James's Avatar
My cars louder than yours
Correct, but if he has or wants to put a free flowing exhaust on his rex then he will have to wire the ports, remove them or use the air pump home plumbed to accuate them......
Old Jul 3, 2002 | 08:44 AM
Josepi's Avatar
Despise Enmity
Make sure you don't have cats if you remove the air pump. Bad ACV/no air pump=dead cats. Dead cats=BAD.
Old Jul 3, 2002 | 11:39 AM
keylempa's Avatar
ok, so lemme get this straight (this whole air pump thing baffles me) If I ever get a free flowing exhaust for an 86 GXL I will have to redo the plumbing from the Air Pump so that I can use all six ports? What about if I got the single exhaust from Mazdatrix that has the actuators in it? Will that be good?
Old Jul 3, 2002 | 02:29 PM
BlackRx7's Avatar
Daily Domestic Killer
if you actually searched for "air pump" or "6 ports" you wouldn't be asking this question, it has been answered it seems like an ungodly amount of times, infinite I guess
Th0m4s
Feb 26, 2019 02:04 AM
rotor_veux
Aug 31, 2015 07:49 PM
Pianoteacherevan
Aug 29, 2015 01:55 PM
