air pump removal??
Old Jul 2, 2002 | 04:06 PM
gz91rx7's Avatar
air pump removal??
OK I have a question. I need to know if anyone has any pics or advice on removing the air pump on my T2.
I have the block off plate and the dual alternator pulley, I am just wondering if anyone has any advice on the removal and reconnection.
Thanks,
Josh
Old Jul 2, 2002 | 04:10 PM
bcty's Avatar
Boost This!
removal.. sooo easy just undo the bolt holding it in and disconnect all the tubes and yank it out! very easy!
Old Jul 2, 2002 | 04:13 PM
gz91rx7's Avatar
thats it!? I dont need to reconnect anything? there has to be more to it than that.
Old Jul 2, 2002 | 04:29 PM
NZConvertible's Avatar
I'm a boost creep...
Removal of the air pump is easy. Just pull off the belts and hoses, unbolt it and remove it! The block-off plate is for the ACV, and that’s just as easy. Just pull off the three vacuum lines and one electrical plug, undo the three nuts and pull the ACV off. Remove the three studs and use shorter bolts to install the block-off plate with a little high-temp sealant or a stock ACV gasket. Cap the three vac lines with rubber caps. The boost sensor line used to come off the AVC, so you’ll need to tee it into the BOV vac line. Here’s my pic.
Old Jul 2, 2002 | 11:13 PM
gz91rx7's Avatar
ah ok! thanks for the help!!!
Old Jul 4, 2002 | 10:39 AM
TRURX7's Avatar
NZ,
woah, i thought the master was on the other side... you gotta show me how you do that
TRU
Old Jul 4, 2002 | 10:44 AM
downwinddave's Avatar
I think this is a driving instructors car, must have dual brake system. Or he has a mod: when your wife slams her foot on the floor...the brake really works!
Old Jul 4, 2002 | 04:12 PM
It was in the way when I changed the fuel filter, so I moved it...
Old Jul 4, 2002 | 07:59 PM
HAILERS's Avatar
HAILERS
Yeah. The master brake cylinder mod. I think I saw it on Ted's site. Then again, maybe I didn't. Slow day.
Old Jul 19, 2002 | 12:14 PM
RestoTII's Avatar
sorry to bring this back, but I just went and removed my pump. I ordered my dual pulley, but I was wondering if it's safe to drive it for a few days without the other belt driving the water pump? also, what do I do with the hose that went into the air pump? It kind of sits right near the engine and wraps around real tight to attach to the air pump, but I didn't want to leave it just hanging out. thanks
Old Jul 19, 2002 | 12:45 PM
MaxRX7's Avatar
hambre y sueño
damn RHD !!
Old Jul 19, 2002 | 01:20 PM
RestoTII's Avatar
I just got my car put back together with no extra pulley work, and so far it isn't making any squealing or showing signs of cavitation. Only problem is it idles HARD and LOW when it's cold. I mean, lumpy... sounds like a cammed musclecar. And it only revs around 500-600 RPm. Is it safe to screw and unscrew adjustments? I've heard you can get into a lot of problems if you put an adjustment out of whack. THanks again
Old Aug 8, 2002 | 01:15 PM
emagdnim's Avatar
RestoTII it's safe to run with the single belt as long as you don't take high RPMs, that's when it slips.
Old Aug 8, 2002 | 01:45 PM
smith88's Avatar
How about if I get the split air cover and block that off, then block off the pipe in front that used to go to the air pump? Do you see anything wrong with that?
Skeese
65
Mar 28, 2017 03:30 PM
c0rpse
Aug 25, 2015 11:50 PM
86glxNA
Aug 22, 2015 08:54 PM
12abridgeport
Aug 17, 2015 06:28 PM
