alpine CDM 9801 install
Old Nov 14, 2010 | 05:15 PM
btbaus's Avatar
hi,
i got this head unit from a friend. he bought a new one, i installed it and he gave me his old alpine.
wiring was easy done in less than 30 minuets..
problem is im not getting a constant 12v at any wire and im not getting the 12v ACC either.
checked the 7.5amp room fuse and the 20amp audio fuse and they both are okay. FSM says wiring is bad and i need to rewire but WTF??? my stock radio was working before i pulled it out... please help.. S5 NA wiring thanks
Old Nov 16, 2010 | 02:38 PM
tegrab18's Avatar
just use a test light to see what is constant 12v. You are bound to find one. If not then run a wire from the battery worse case scenario but ide try to find a wire inside that will have a constant 12v. You could rewire but sometimes thats a pain in the ....
Old Nov 19, 2010 | 01:56 AM
btbaus's Avatar
yeah ive been looking with my DMM but none of the original radio wiring is showing voltage.. ill just rewire..... weird huh
Old Nov 28, 2010 | 08:42 AM
chinaman's Avatar
You probably rewired already but, how is there no voltage from the original wires and your original radio was working? You probably blew a fuse
Old Nov 29, 2010 | 12:49 AM
dblboinger's Avatar
What year is your car?
Old Nov 29, 2010 | 01:11 AM
dblboinger's Avatar
The +12 battery should be on a blue/red wire at pin 1C of J-01 (which plugs into the rear of the stock radio). There are 2 fuses in this line, the 60A MAIN fuse under the hood and a 7.5A ROOM fuse under the dash.
The +12v Ignition should be a blue/white wire at pin 1A of J-01. This one also has 2 fuses, the 100A MAIN fuse under the hood, through the ACC terminal of the ignition switch to the
20A AUDIO fuse under the dash.
If you're reading 0v everywhere, check your battery power and ground connections.
Here's a link to the wiring diagram for a '91 RX7.
http://www.wright-here.net/files/man...ingDiagram.pdf
Old Nov 30, 2010 | 01:34 AM
btbaus's Avatar
1990 S5. i check all the fuses except for the 100amp main. so i will check dat in the morning. all the other fuses are okay. i grounded the radio on the drivers side dash near where your knee goes. thers a triangular piece of placstic there .. thanks for your help
Old Nov 30, 2010 | 02:14 PM
btbaus's Avatar
ye3ah all the fuses are okay. ill ground the radio elsewhere see if that works..
Old Dec 1, 2010 | 10:49 PM
dblboinger's Avatar
You can't ground to plastic. Gotta be metal that's electrically connected to the negative battery terminal.
Old Dec 2, 2010 | 12:26 PM
btbaus's Avatar
the ring terminal is sandwiched between plastic and metal... guess its not good enough? which cable is electrically connected to the negative battery terminal?
Old Dec 6, 2010 | 01:05 AM
dblboinger's Avatar
Got an ohm-meter? Connect one lead to the battery negative and touch the other to your selected "grounding" point. It should read very near 0 ohms.
Old Dec 6, 2010 | 07:45 PM
btbaus's Avatar
my original ground point was not good enough. this time i grounded it at a 10mm nut above the accelerator pedal and everything works great.. thanks guys
24seven_dada
20
Nov 10, 2018 12:03 PM
sinclair7seven
11
Sep 11, 2015 10:15 AM
astrum
Sep 7, 2015 11:41 PM
Enzo1944
Sep 6, 2015 08:57 AM
