Power FC fc3s pfc issues
Old Oct 5, 2010 | 07:17 PM
4WDrift's Avatar
skookum
fc3s pfc issues
long story sumd up fast is i got a used half bridgeport 13bt with a ap engineering pfc. When it starts it wants go into "limp mode" as in when i give it throttle off idle it will rev for half and second and cut fuel then rev then cut fuel so on so forth. i noticed my vta1 (narrow) is reading 4.99 volts constantly even when pressing the plunger in with my finger. going to look for a short in the wiring cause it said at 4.99 volts when it was un plugged but could this be the source of my limp mode?
Old Oct 5, 2010 | 07:41 PM
arghx's Avatar
rotorhead
the PFC doesn't really have "limp mode" but clearly you aren't getting a signal on the full range TPS wire, probably due to your previous owner's wiring mistakes.
Old Oct 5, 2010 | 09:36 PM
4WDrift's Avatar
skookum
just who i was hoping would respond^
ok so i was hasty to say that it stayed at a constant 4.99 volts. at idle postion it reads 4.2-4.4 volts when off idle it goes to 4.99 and it highlighted. does this sound like what could be causing this issue? i did some resistance checks on the wires but for pin 2g i got two wires both br/w from the tps's that read .7ohms and the rest are reading Kohms and all wires to pin 2f where kohms....strange. will do some more digging tomorrow just throw out ideas.
Old Oct 6, 2010 | 12:53 AM
arghx's Avatar
rotorhead
if the TPS voltages are not in spec then the computer won't be able to properly calculate how much additional fuel to inject as the throttle opens. What are your VTA2 voltages?
You do have an s5 TPS right? This is an AP Engineering PFC in an s5 car?
Old Oct 6, 2010 | 06:31 AM
4WDrift's Avatar
skookum
correct and correct. voltages on vta2 are around 2 at idle (alittle high) and 4.80 at wot. Also there is a **** just after art that i believe is fuel temp that i dont have that reads 4.99, and the omp is deleted reading .07 and o2 sensor is .01 but turned off i believe since there isnt one
Old Oct 6, 2010 | 09:41 AM
arghx's Avatar
rotorhead
first test the resistance sweep on the TPS plungers using an analog multimeter.
Old Oct 7, 2010 | 07:52 PM
4WDrift's Avatar
skookum
installed another set of tps sensors, I plugged them in and watched their voltages change across the range to make sure they were good, installed them and adjusted. turns out since i am running a half bridge and the idle is set at over 1200 the narrow range never gets used. Either way the car stopped doing its "limp mode" now its just getting my warm start injection taken car of. thanks for the help
Old Oct 13, 2010 | 08:50 AM
4WDrift's Avatar
skookum
thought i would update this alittle bit. If your running a high idle around 1500 or so, i found you have to remove the spring for the narrow range tps adjustment screw to get it to read in spec. havent warmed the vechile up and readjusted but just throwing it out there
Old Oct 14, 2010 | 04:16 PM
arghx's Avatar
rotorhead
yeah that's mostly an s5-specific issue. the FD TPS is like a 90s Honda TPS and is adjusted differently. The s4 TPS is narrow range only and just has one adjuster screw.
Old Oct 17, 2010 | 05:18 AM
thewird's Avatar
The PFC does have some sort of limp mode. If the TPS goes out of spec, the car starts crackling in the exhaust (not sure exactly what its doing) and the check engine light flashes (on a rhd FD). I experienced this once when tuning a RHD FD where the TPS would go out of spec with more then 1/2 throttle or so. It seems like some sort of fuel and/or ignition cut but it feels and sounds weird and unhealthy.
thewird
Old Oct 17, 2010 | 08:36 AM
4WDrift's Avatar
skookum
its a fuel cut, i could watch my wideband and see the fuel completely lean out to nothing, then come back, then nothing
Old Oct 17, 2010 | 09:22 AM
arghx's Avatar
rotorhead
Well I would expect it to run like complete crap but I guess "limp mode" isn't the term I'd normally use for that. It would be interesting to unplug the TPS and take a log with the Datalogit to see what is happening.
Old Oct 18, 2010 | 11:54 AM
4WDrift's Avatar
skookum
i will work on that once my datalogit comes in
Old Jun 15, 2011 | 12:06 PM
dougiepants's Avatar
ok so lets say you are having this issue on the S4? the motor idles but you can tell it is just getting to much fuel. the vta1 is at 4.99v and the vta2 works perfect from .6v-4.86v thru the sweep. Im curious how to sending a signal to the vta1 or how to fix this issue please...
Old Jun 16, 2011 | 05:55 AM
Banzai-Racing's Avatar
Rotary Specialists
Pretty simple, just follow the installation instructions. http://www.banzai-racing.com/S4_PFC_install.htm
-The short 8" unterminated wire marked FRT allows you to install a full range TPS (S5 or FD).
-If you are using the S4 TPS, splice the FRT wire to the 3F wire
Finally figure out that you adjust the TPS with the screw on the throttle?
rgordon1979
40
Mar 15, 2022 12:04 PM
24seven_dada
20
Nov 10, 2018 12:03 PM
Enzo1944
Sep 6, 2015 08:57 AM
Steven_McKinley
Sep 5, 2015 10:48 AM
