5th and 6th port actuators
Old Jul 19, 2010 | 10:41 PM
GreenMachine's Avatar
My actuators on my GSL-SE wont open, at first i thought they were seized so i cleaned them but then i realized there was no hoses or anything connected to them. Is there supposed to be? And if so were do they come from and go?
Thanks
Shea
360
Old Jul 20, 2010 | 12:39 PM
RotaryRocket88's Avatar
Top Down, Boost Up
I believe it is the same as with the S4 actuators, which are fed through two small holes in the LIM. The actuators have gaskets that seal them against the LIM surface, and there is a metal hardline running around the back side that feeds them from the split air pipe.
If the actuators move freely when pressed by hand, you may need to look into an alternative activation method. My S4 NA's ports never opened properly; even when I had the stock exhaust system. My solution was an air pump fed system that was controlled by an RPM switch and a solenoid. I have a writeup on it here: https://www.rx7club.com/2nd-generation-specific-1986-1992-17/activating-aux-ports-vdi-rpm-switches-907824/.
Old Jul 21, 2010 | 06:57 PM
Is there a way i can just keep them open al the time?
Old Jul 22, 2010 | 02:52 PM
Top Down, Boost Up
Yes, if you want to sacrifice low-end torque. There's a reason the ports stay closed until 3800 RPM.
Old Jul 23, 2010 | 12:05 AM
k thank you for your help
24seven_dada
20
Nov 10, 2018 12:03 PM
alexdimen
20
Oct 23, 2015 01:50 PM
23Racer
Race Car Tech
Sep 21, 2015 10:48 AM
teebeekay
Sep 16, 2015 01:54 PM
doritoloco
Sep 5, 2015 12:41 PM
