fouled ngk spark plugs
Old Jul 5, 2010 | 10:00 PM
94fdtyler's Avatar
KC_RX7
CA fouled ngk spark plugs
so the other day i started sputtering really bad and i decided to head up to the local parts store and pick up some new spark plugs. i bought the correct one, two leading and two trailing. so i go home pop the hood and start replacing them one by one. come to find out that some idiot had put in 3 leading and 1 trailing. so thats not even the best part. all four were charred black and nasty looking. obviously fouled. i just thought i would share that with anyone who cares. i am a newbie to the rotary but even i had the smarts to do some research before i did even a simple task.
Old Jul 6, 2010 | 02:45 PM
rxtasy3's Avatar
since ur dealing with leading and trailing specific plugs, i think fc. but seeing ur user id, i take it the car is an fd.
Old Jul 9, 2010 | 06:59 PM
Todd Van's Avatar
I am new to this----what is a leading and trailing plug?
Old Jul 9, 2010 | 07:22 PM
the7wizard's Avatar
wow, ngk any others better?
Old Jul 10, 2010 | 12:49 AM
rxtasy3's Avatar
the spark plugs. a rotary engine has one leading and one trailing plug per rotor. have u not done any research at all on these engines? this should be of some interest to ya.
http://auto.howstuffworks.com/rotary-engine.htm
Old Jul 10, 2010 | 12:50 AM
rxtasy3's Avatar
the vast majority of rotary owners use ngk.
Old Jul 10, 2010 | 01:33 AM
gracer7-rx7's Avatar
needs more track time
Yep. Can't get much better than the stock NGK plugs. I get mine from rx7.com. I change them roughly every 10-15k miles. Rotaries love fresh spark plugs.
Old Jun 22, 2012 | 07:35 PM
graveltrapp's Avatar
Could try a different temp plug, Racing beat has a good write up on spark plugs for the rotary.
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
Frox
Feb 27, 2016 11:11 AM
The1Sun
Sep 15, 2015 04:45 PM
The1Sun
Sep 7, 2015 10:21 PM
