Power FC looking for a safe timeing map to get stared tuning with FD3S
Old Jun 21, 2010 | 05:15 AM
douwe's Avatar
I have a fresh short block from Mazda, well just run in, in my s7 going single
turbo TO4E just waiting on my FMIC and radiator witch should arrive in a day or
two, factory port and fuel-injectors but have a bosh 440 in-tank pump any help
to get started tuning would be great thanks.
Old Jun 21, 2010 | 06:28 PM
arghx's Avatar
rotorhead
Do you have a Datalogit?
Old Jun 22, 2010 | 02:52 PM
douwe's Avatar
yea but u no datalogit still no invite to the e group
Old Jun 23, 2010 | 09:22 AM
arghx's Avatar
rotorhead
http://bdc.cyberosity.com/main.php?g2_itemId=14542
Old Jun 23, 2010 | 11:09 PM
cewrx7r1's Avatar
Eye In The Sky
The base map on the PFC is a safe place to start from.
You need to understand:
(1) rotory tuning theory and how to do it
(2) what the PFC and DL can do
(3) have all the correct parts on the engine to safely be tuned to the desired boost level
Old Jun 24, 2010 | 04:44 PM
douwe's Avatar
i was told the base timing maps on the pfc were to advanced for a single turbo, i just want some safe timing maps so i can tune the afr and then drive it to a dyno (about 400km) to fine tune the timing, timing is something in a rota i dont fell safe playing around with!
thanks
Old Jun 24, 2010 | 07:42 PM
arghx's Avatar
rotorhead
check out the basemap library I posted above from BDC Motorsports.
As far as the PFC base timing calibration, well it's not bad except the trailing timing is on the aggressive side in some places. If you retard the trailing (increase split) by about 5 degrees from the P15-P20 rows then the timing would be safer.
Old Jun 25, 2010 | 04:42 PM
douwe's Avatar
thanks for your help hope to get it going and tuning today thanks again
Jun 26, 2016 10:21 AM
Engine Management Forum
11
Nov 9, 2015 01:15 PM
sen2two
AEM EMS
Oct 23, 2015 07:51 PM
Microtech
Aug 23, 2015 11:04 AM
20B Forum
Aug 19, 2015 01:47 PM
