do i need rpm module pills
Old Jun 19, 2010 | 02:06 PM
canonize-ryda's Avatar
do i need the proper rpm module pills for a rpm activated switch or can i tune it to a certain rpm without the pills? the switchis for a electronic air pump
Old Jun 21, 2010 | 12:08 PM
jjcobm's Avatar
Are you experienced?
If you are talking about activating the VDI and 5th and 6th ports, you need to have a functioning air pump and the rest of the emissions equipment.
Now, it seems you are trying to "tune" the VDI & 5th 6th ports to open at your RPM of liking. The only way without having to buy the equipment needed for this would be to run an RTEK chipped ECU. With the RTEK I believe you should have control over the solenoids that activate the VDI & 5th & 6th ports.
http://www.pocketlogger.com/
Otherwise, the other option is to buy the appropriate RPM switches that they sell on summit racing which provide air to the VDI and 5th 6th port solenoids to open up the ports. There are a few posts on this and I am not too informed about it so thats as far as I will go on the RPM switch.
Hope that helps...
Old Jun 21, 2010 | 12:12 PM
well on rotary resurrection they have a thing saying that ont my engine u can hook up and electric air pump and u need a vaccuum solenoid a air pump and hosing a a 4 prong relay. using this setup i can have my ports open at 3800 because as of now i dont have anyexhaust backpressure. no cat and free flow mufflers. so i was wondering if the msd rpm activated switch needs the module pills or not. it says i do but rr88 says they can be tuned just themselves.
Old Jun 21, 2010 | 12:19 PM
jjcobm's Avatar
If this is an s4 (which by your post sounds like it is), the easiest way to solve this would be to pay an exhaust shop to just weld a pipe into your exhaust to activate the 5th and 6th ports.
Otherwise, RR88 is usually correct and I would trust 99% of the things he would tell you. I don't see any reason why the module wouldn't work by itself.
If in doubt, contact MSD directly...
Old Jun 21, 2010 | 02:35 PM
RotaryRocket88's Avatar
Top Down, Boost Up
MSD RPM switches do use "pills" for the settings. They're also overpriced, which is why I bought Summit brand switches.
MSD switch:http://www.summitracing.com/parts/MSD-8950/
Summit switch: http://www.summitracing.com/parts/SUM-830450/
Prediict
32
Nov 18, 2015 08:41 AM
dona1326cosprings7
Oct 29, 2015 06:47 AM
RX200013B
Haltech Forum
Oct 12, 2015 09:45 PM
eplusz
15
Oct 7, 2015 04:04 PM
baix2
Power FC Forum
Sep 28, 2015 09:40 AM
