Fabrication Post your questions and projects on Fabrication of Interior or Exterior or custom audio and electronics here.
How to fill floorboard holes on the cheap
Old Jun 17, 2010 | 06:36 PM
Skidtron's Avatar
Being poor sucks!
I was at harbor frieght the other day and came up with this. I think its a simple solution to an annoying problem; which is welding all those holes shut so the outside stays outside lol. Most people probably won't care but it might keep someone from wasting hours of their life welding.
Hit the link below for the video
http://www.youtube.com/user/skidtron#p/u/0/IG9UOUzkrbM
Old Jun 19, 2010 | 08:11 PM
Saks_RX7's Avatar
OR you can get some Bondo and the mesh tape that goes with it. 5 minute fix for relatively cheap.
Old Jun 19, 2010 | 09:30 PM
turboIIrotary's Avatar
then you can watch the holes rust away
Old Jun 26, 2010 | 12:17 PM
Skidtron's Avatar
Being poor sucks!
bondo and mesh tape? sounds like a pain in the *** to me..... pop rivets are super easy every hole in the floor board filled in like 7 minutes.
Old Jun 26, 2010 | 06:22 PM
evot23's Avatar
Classy
Adding the RTV is a good move to keep it weathertight. Nice...easy...
Old Jul 19, 2011 | 12:41 PM
snowbreaker's Avatar
now 17 with 2 cars **)
you guys had it all easy , took sheet metal over top the hole i had and welded it down
Old Jul 23, 2011 | 10:21 AM
Aaron Cake's Avatar
Engine, Not Motor
For FACTORY holes, panel bonding adhesive and a small patch is the way to go. For RUST holes, the rust must be cut out and a patch panel welded in place.
Old Mar 11, 2012 | 08:23 PM
full-cruise's Avatar
D.I.L.U.S.I.
for a smooth look just spray foam, sand smooth, rattle can
Old Mar 11, 2012 | 10:25 PM
Jibaro 12A's Avatar
searching...
Whats wrong with welding them shut?
Old Mar 12, 2012 | 05:48 PM
D.I.L.U.S.I.
yea thats deff the best way to go..
Old Mar 24, 2012 | 01:36 PM
Richdip's Avatar
what if you havent welded in like 4 years lol
Old Jun 12, 2013 | 05:25 PM
protunedperformance's Avatar
I really like the rivet idea. Super easy and cost effective. Good choice skidtron. Personally i welded mine shut cause i have the time and access to all the necessary equipment.
Old Jul 4, 2013 | 03:32 PM
midnight mechanic's Avatar
acdelco d1906 Nkg 49034
USeal Band 6 in. Aluminum Foil Self-Adhesive Repair Tape-8872AF6 at The Home Depot
It is kinda like dynamat
Old Aug 30, 2013 | 08:07 PM
marcofd's Avatar
Using rivets is the best way to go, works like a charm.
squirrels
Sep 1, 2024 09:52 AM
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
Boans
V-8 Powered RX-7's
Sep 25, 2015 04:34 PM
Devon Murray
Sep 25, 2015 09:41 AM
