3rd gear grinding 1986 gxl
Old Jun 16, 2010 | 12:11 AM
Volcom07951's Avatar
Arrow 3rd gear grinding 1986 gxl
My rx7 Has been grinding in 3rd gear every other gear seems
to be fine, I only have trouble getting into 3rd unless the Rpms
are below 3k and it won't grind and even then it feels like I have to
push the shift **** a little harder to get into 3rd than I have to for
other gears
just trying to figure out what's going on so I can fix it, I've
been told it could be the transmission fluid or shift linkage?
I'm not sure? A friend reccomended I put in a short shifter
but I have my doubts that will resolve the problem
after reading a few posts I think it might but the bushings?
But I don't know and I don't know how to check for these
problems. Help would be greatly appreciated!
It is a 1986 rx7 gxl has 85,331 miles, and is completly stock
Old Jun 16, 2010 | 03:00 PM
RotaryRocket88's Avatar
Top Down, Boost Up
Your 3rd gear synchro is wearing out. The only cure is a rebuild or replacement transmission.
Old Jun 16, 2010 | 09:41 PM
So that would be the only solution?
Any idea how much it would cost for
a rebuild or replacement?
And is it a serious problem, as in something
that needs to be addressed right away
I'm a little short on money so it would be a while
before I could do anything
Old Jun 17, 2010 | 12:07 AM
Top Down, Boost Up
For the time being, just take it easy shifting into 3rd. Rev match when shifting (allow RPMs to drop or blip the throttle on a downshift). You can try a quality synthetic gear oil as a band-aid. Synchros don't fix themselves, they have to be replaced. A rebuild can cost you $500-$1000+ depending on if you pull the transmission and re-install it yourself. A replacement used NA transmission can likely be found for under $100.
Old Jun 17, 2010 | 01:11 AM
Thanks for the help, I appreciate it. I will try some synthetic gear oil
hopefully it'll work for the time being, and I'll begin
looking for a replacement transmission
Old Jun 17, 2010 | 06:38 PM
Kentetsu's Avatar
On 1st gen trannys, sometimes the synchros will get gummed up and start getting bitchy. A lot of us have had success by running a 50/50 mix of gear lube and automatic transmission fluid. The ATF has plenty of lube for this, but also a lot of detergents that will clean out the synchros and improve shifting action. You might give this some thought.
Short shift to fix a shifting issue. lmao
Good luck...
Old Jun 17, 2010 | 09:47 PM
I will definantly try your suggestion, how much 50/50 gear lube and automatic transmission fluid would i use?
Old Jun 18, 2010 | 12:29 AM
Top Down, Boost Up
He was suggesting a 50/50 mix of standard gear lube (75W-90 or 80W-90) and ATF. An NA transmission has a capacity of 2.1 quarts, so that would be 1.05 quarts of each. Capacities are listed in the FSM technical data section. You can combine the ATF trick with synthetic gear lube to give yourself the best chance. Mazdatrix sells a brand called NEO that works very well.
Also, before draining your transmission, be sure you can remove the fill plug. If it's seized, you'll end up with an empty transmission and no way to fill it back up.
Old Jun 18, 2010 | 08:20 PM
Thanks! Everything has been really helpful!
Old Jun 19, 2010 | 03:43 AM
Kentetsu's Avatar
Let us know how it works out for you.
Old Jun 20, 2010 | 02:07 AM
I'll keep you posted I get paid this coming week so I'll be changing the tranny fluid
as soon as I can!
Cuzzynz
141
May 28, 2020 09:23 AM
24seven_dada
20
Nov 10, 2018 12:03 PM
teebeekay
Sep 16, 2015 01:54 PM
REX7&Z32TT
Sep 9, 2015 05:16 AM
