Couple questions about my new turbo
Old May 30, 2010 | 05:15 PM
OregonTII's Avatar
Slowly building
Been searching through the pile of parts that came with my new project, and have run into a few questions. I apologize in advance if my terminology is off a bit, I am still a noob
The person I bought the car from had gotten a 3" down pipe, for the life of me I cannot find a decent picture of how my exhaust is supposed to connect to the turbo. The flanges between the exhaust and turbo don't match, I assume the down pipe just wasn't meant for this turbo? Or maybe I am missing a piece? Anyone got a good picture of their stock turbo with a aftermarket exhaust?
Also the section of the turbo that connects to the manifold on the engine has a few cracks in it. Do I need to replace this? I am hoping to get this car going without buying any major parts.
Turbo
downpipe
Cracks in turbo
Old May 30, 2010 | 10:02 PM
RotaryRocket88's Avatar
Top Down, Boost Up
Your turbo is missing the cover plate that goes on the back. Take a look through the classified section; I'm sure someone has a picture in there.
The cracks in the turbine housing are common, and will be ok.
Old May 30, 2010 | 10:40 PM
OregonTII's Avatar
Slowly building
Figured I was missing a piece, this is my first turbo and I am still trying to learn how it all goes together. Been searching around, just havent found a decent picture yet, I will keep looking.
Thanks for the info.
Old May 31, 2010 | 02:51 PM
Top Down, Boost Up
Here, I remembered I had this picture of my machined S5 cover plate. This is the inside of it, and it is larger than the S4 version. Metal was machined out to allow the wastegate to open further & allow more flow.
Old May 31, 2010 | 04:03 PM
1bad6's Avatar
you should get a new exhaust housing
Old Jun 1, 2010 | 11:03 PM
OregonTII's Avatar
Slowly building
Wow thanks, that is exactly what I was after.
<3 this forum and the people here. So much help
smikels
Rtek Forum
May 12, 2016 12:34 AM
Frisky Arab
13
Aug 18, 2015 05:30 PM
smikels
Aug 18, 2015 01:26 PM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
